Introduction
Follow this guide to replace a broken or cracked screen on a Google Pixel 5.
Unlike previous Google Pixels models, the Pixel 5’s screen is reinforced with a metal frame. The earpiece speaker is also glued onto the back side of the screen.
Heat an iOpener and apply it to the bottom edge of the screen for one minute.
Apply a suction cup to the screen, as close to the heated edge as possible.
Pull up on the suction cup with strong, steady force to create a gap.
Insert the opening pick into the gap.
Slide the opening pick back and forth along the bottom of the screen to slice the adhesive.
Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
Apply a heated iOpener to the left edge of the screen for one minute.
Insert another opening pick into the bottom left corner of the screen.
Slide the opening pick around the left corner.
Continue to slide the pick up towards the front camera to slice the adhesive on the left edge of the screen.
Leave the pick inserted to prevent the adhesive from re-sealing.
Insert another opening pick into the top left corner of the screen.
Slide the pick around the front camera and across the top edge of the phone.
Slide the pick to the top right corner of the phone and leave the pick inserted.
Insert an opening pick into the bottom right corner of the screen.
Slide the pick up to the top right corner to slice the last edge of adhesive.
Use the opening pick from the top left corner to lift up the left edge of the screen a few millimeters. This will keep the clips from snapping back down into the case.
Lift up on the right side of the screen and open up the phone like a book.
Use tweezers to grip the screen connector cover securing the screen flex cable.
Push the clip in towards the connector to unlatch it.
