Google Pixel 4 Screen Replacement
  1. Google Pixel 4 Screen Replacement, Remove the SIM card tray: step 1, image 1 of 3 Google Pixel 4 Screen Replacement, Remove the SIM card tray: step 1, image 2 of 3 Google Pixel 4 Screen Replacement, Remove the SIM card tray: step 1, image 3 of 3
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the left edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
  2. Google Pixel 4 Screen Replacement, Heat the back panel glass: step 2, image 1 of 1
    • Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Google Pixel 4 Screen Replacement, Apply a suction cup: step 3, image 1 of 2 Google Pixel 4 Screen Replacement, Apply a suction cup: step 3, image 2 of 2
    • Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
  4. Google Pixel 4 Screen Replacement, Insert an opening pick: step 4, image 1 of 2 Google Pixel 4 Screen Replacement, Insert an opening pick: step 4, image 2 of 2
    • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  5. Google Pixel 4 Screen Replacement, Begin to slice the adhesive: step 5, image 1 of 3 Google Pixel 4 Screen Replacement, Begin to slice the adhesive: step 5, image 2 of 3 Google Pixel 4 Screen Replacement, Begin to slice the adhesive: step 5, image 3 of 3
    • Slide the opening pick across the bottom towards the left corner to slice the adhesive.
    • With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  6. Google Pixel 4 Screen Replacement, Slice the lefthand-side adhesive: step 6, image 1 of 1
    • Prepare an iOpener and apply it on the left edge of the phone for one minute.
  7. Google Pixel 4 Screen Replacement: step 7, image 1 of 2 Google Pixel 4 Screen Replacement: step 7, image 2 of 2
    • Insert a second opening pick underneath the back panel directly over the charge port.
    • Slide the opening pick to the bottom left corner of the phone.
  8. Google Pixel 4 Screen Replacement: step 8, image 1 of 2 Google Pixel 4 Screen Replacement: step 8, image 2 of 2
    • Slide the opening pick around the bottom left corner and across the left side of the phone to slice the adhesive.
    • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
    • Stop when you reach the top left corner, near the camera, and leave the pick inserted.
  9. Google Pixel 4 Screen Replacement, Slice righthand-side adhesive: step 9, image 1 of 1
    • Prepare an iOpener and apply it on the right edge of the phone for one minute.
  10. Google Pixel 4 Screen Replacement: step 10, image 1 of 3 Google Pixel 4 Screen Replacement: step 10, image 2 of 3 Google Pixel 4 Screen Replacement: step 10, image 3 of 3
    • With the first two opening picks still in place, insert a third pick on the lower part of the righthand side.
    • Slide the opening pick up towards the top of the phone, slicing the right side's adhesive.
    • Stop when you reach the top right corner, and leave the pick inserted.
  11. Google Pixel 4 Screen Replacement, Slice the top-side adhesive: step 11, image 1 of 2 Google Pixel 4 Screen Replacement, Slice the top-side adhesive: step 11, image 2 of 2
    • Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
  12. Google Pixel 4 Screen Replacement, Lift up the back panel: step 12, image 1 of 3 Google Pixel 4 Screen Replacement, Lift up the back panel: step 12, image 2 of 3 Google Pixel 4 Screen Replacement, Lift up the back panel: step 12, image 3 of 3
    • Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
    • Do not try to pull the panel all the way off yet, as it is still connected to the phone.
  13. Google Pixel 4 Screen Replacement: step 13, image 1 of 2 Google Pixel 4 Screen Replacement: step 13, image 2 of 2
    • Continue swinging open the back panel until you can rest it on the left edge the phone, being careful not to put any stress on the attached ribbon cable.
    • During reassembly, this is a good point to power on your phone and test all functions before re-sealing the back panel. Be sure to power your phone back down completely before you continue working.
  14. Google Pixel 4 Screen Replacement, Disconnect the battery: step 14, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Remove the five T3 Torx screws securing the battery connector shield:
    • Four 4.0 mm screws
    • One 2.1 mm screw
  15. Google Pixel 4 Screen Replacement: step 15, image 1 of 2 Google Pixel 4 Screen Replacement: step 15, image 2 of 2
    Buy
    • Use a pair of tweezers to remove the battery connector shield.
  16. Google Pixel 4 Screen Replacement: step 16, image 1 of 2 Google Pixel 4 Screen Replacement: step 16, image 2 of 2
    • Whenever you use the spudger near the battery, be very careful not to puncture the battery.
    • Using the pointed end of a spudger, pry the battery connector straight up from the motherboard to disconnect the battery.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  17. Google Pixel 4 Screen Replacement: step 17, image 1 of 2 Google Pixel 4 Screen Replacement: step 17, image 2 of 2
    • Using the flat end of a spudger, gently fold the battery cable over so it doesn't accidentally make contact during the rest of your repairs.
  18. Google Pixel 4 Screen Replacement, Disconnect the back panel connector: step 18, image 1 of 1
    • Use a T3 Torx driver to remove the two 4 mm screws securing the back panel connector cover.
  19. Google Pixel 4 Screen Replacement: step 19, image 1 of 2 Google Pixel 4 Screen Replacement: step 19, image 2 of 2
    • Use a pair of tweezers to remove the back panel connector cover.
  20. Google Pixel 4 Screen Replacement: step 20, image 1 of 2 Google Pixel 4 Screen Replacement: step 20, image 2 of 2
    • Using the pointed end of a spudger, pry up and disconnect the back panel connector.
  21. Google Pixel 4 Screen Replacement, Remove the back panel: step 21, image 1 of 1
    • Remove the back panel.
    • During reassembly, follow this guide to install custom-cut adhesives for your device.
    • Follow this guide if you are using a pre-cut adhesive card.
  22. Google Pixel 4 Screen Replacement, Front Camera and Sensor Assembly: step 22, image 1 of 1
    • Use a T3 Torx driver to remove the four 4 mm screws securing the camera connector cover.
  23. Google Pixel 4 Screen Replacement: step 23, image 1 of 3 Google Pixel 4 Screen Replacement: step 23, image 2 of 3 Google Pixel 4 Screen Replacement: step 23, image 3 of 3
    Buy
    • Using a pair of tweezers, tilt the camera cover up and slide it out of the retaining slot on the upper right corner of the phone to remove.
  24. Google Pixel 4 Screen Replacement, Disconnect the camera and sensor connectors: step 24, image 1 of 3 Google Pixel 4 Screen Replacement, Disconnect the camera and sensor connectors: step 24, image 2 of 3 Google Pixel 4 Screen Replacement, Disconnect the camera and sensor connectors: step 24, image 3 of 3
    • Using the pointed end of a spudger, pry the camera and sensor connectors straight up from the motherboard.
  25. Google Pixel 4 Screen Replacement: step 25, image 1 of 2 Google Pixel 4 Screen Replacement: step 25, image 2 of 2
    • Disconnect the laser module connector.
  26. Google Pixel 4 Screen Replacement, Remove the front camera and sensor assembly: step 26, image 1 of 1
    • Use a T3 Torx driver to remove the two 2.4 mm screws securing the front camera and sensor assembly.
  27. Google Pixel 4 Screen Replacement: step 27, image 1 of 3 Google Pixel 4 Screen Replacement: step 27, image 2 of 3 Google Pixel 4 Screen Replacement: step 27, image 3 of 3
    • Use a pair of tweezers to remove the front camera and sensor assembly.
  28. Google Pixel 4 Screen Replacement, Screen: step 28, image 1 of 2 Google Pixel 4 Screen Replacement, Screen: step 28, image 2 of 2
    • Use a spudger to disconnect the display connector from the motherboard.
  29. Google Pixel 4 Screen Replacement, Slice the screen adhesive: step 29, image 1 of 1
  30. Google Pixel 4 Screen Replacement: step 30, image 1 of 3 Google Pixel 4 Screen Replacement: step 30, image 2 of 3 Google Pixel 4 Screen Replacement: step 30, image 3 of 3
    • This process will almost always destroy the OLED display panel. Only proceed if you are replacing an already-broken screen.
    • Apply a suction cup to the heated edge of the screen.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Pull up on the suction cup with strong, steady force to create a gap between the screen and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply heat to the edge and try again.
    • Depending on the age of your phone, this may take significant force. If you are having trouble, apply more heat and try again.
  31. Google Pixel 4 Screen Replacement: step 31, image 1 of 2 Google Pixel 4 Screen Replacement: step 31, image 2 of 2
    • Slide the opening pick down the right bezel of the phone, between the display and the frame, to slice the adhesive.
    • Leave the pick inserted in the bottom right corner.
  32. Google Pixel 4 Screen Replacement: step 32, image 1 of 2 Google Pixel 4 Screen Replacement: step 32, image 2 of 2
    • Insert a second opening pick underneath the screen in the top left corner of the phone, near the front-facing camera cutout.
    • If this is difficult, you may need to reapply an iOpener to the upper edge of the screen.
    • Slide the opening pick around the corner and down the left side of the phone, stopping about halfway down, and leave the pick inserted.
  33. Google Pixel 4 Screen Replacement: step 33, image 1 of 2 Google Pixel 4 Screen Replacement: step 33, image 2 of 2
    • Insert a third opening pick under the screen in the middle of the right edge of the phone and twist to separate the screen.
  34. Google Pixel 4 Screen Replacement, Tilt the screen up: step 34, image 1 of 2 Google Pixel 4 Screen Replacement, Tilt the screen up: step 34, image 2 of 2
    • Tilt the screen up along the left edge of the phone.
    • Slide the display connector out of the hole near the motherboard to separate the screen from the rest of the phone.
    • The connector will slide out without any force.
  35. Google Pixel 4 Screen Replacement, Remove the screen: step 35, image 1 of 1
    • Remove the screen.
    • You will have to thread the replacement screen's display cable through the motherboard cutout. If you are having trouble, you can always loosen and partially remove the motherboard.
    • If you are using a custom-cut adhesive, follow this guide for instructions on how to apply adhesive to the replacement screen.
    • Be sure to test your repairs before you affix the screen with adhesives.
    • If you are using Tesa tape to reattach the screen, follow this guide.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
Carsten Frauenheim
116,243 Reputation
339 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,525 Guides authored
Past 24 Hours: 7
Past 7 Days: 46
Past 30 Days: 249
All Time: 34,037
