Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement
Views: 8.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
31
Past 30 Days:
134
All Time:
8,581
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 - 30 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you how to replace the M.2 Solid State Drive in your Lenovo IdeaPad Flex 5 1570 laptop. The solid state drive (SSD) is a storage device, which houses all the data on your device, from the filesystem to the operating system. Problems that you may experience from a faulty SSD are a corrupted memory or OS, difficulty starting the computer, or missing files. You may also run into a situation where your SSD becomes too full and you run out of storage space on your computer, which may prompt an upgrade. Replacing or upgrading the SSD in your device should alleviate any of these problems in a traditional laptop.
However, the Flex 5 1570 is capable of running two storage devices in tandem, utilizing both a PCIe port and a SATA port. Typically this would be used to run a hard disk drive, which is slower, but cheaper for more memory, and a solid state drive for programs and files which need to be accessed quickly. Because there may be two storage devices on your device, you may have to do some investigating as to which one is faulty. If you suspect your computer is having storage problems and replacing the SSD didn’t help, check out our Lenovo IdeaPad Flex 5 1570 Hard Drive Replacement Guide.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Back Panel: step 1, image 1 of 2 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Back Panel: step 1, image 2 of 2
      • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
      Ask FixBot
    2. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: step 2, image 1 of 3 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: step 2, image 2 of 3 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: step 2, image 3 of 3
      • Use a spudger to pry open the back case at the two hinge cutouts.
      • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
      Ask FixBot
    3. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: step 3, image 1 of 2 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: step 3, image 2 of 2
      • Once all the clips have been disengaged, lift off the back cover.
      Ask FixBot
    1. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Battery Disconnect: step 4, image 1 of 3 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Battery Disconnect: step 4, image 2 of 3 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Battery Disconnect: step 4, image 3 of 3
      • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
      • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
      Ask FixBot
    1. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, M.2 SSD: step 5, image 1 of 3 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, M.2 SSD: step 5, image 2 of 3 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, M.2 SSD: step 5, image 3 of 3
      • Remove the single 2.9 mm screw holding down the solid state drive with a Phillips #0 screwdriver.
      • The SSD will rise to rest at an angle once the screw is removed.
      Ask FixBot
    2. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: step 6, image 1 of 3 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: step 6, image 2 of 3 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: step 6, image 3 of 3
      • Pull the solid state drive out of its port to the right at a similar angle to which it rests.
      • Remove the SSD from the device.
      Ask FixBot
Austin Blakely
23,335 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
1 Guide Comment
Very informative, the pictures were most helpful.
IDK if you've got a guide detailing the drive cloning process or not but that would put the icing on the cake.
Thank you
FaQue Microsoft - Reply Share
Past 24 Hours: 2
Past 7 Days: 31
Past 30 Days: 134
All Time: 8,581
