Google Pixel 3 Charging Assembly Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Google Pixel 3 Charging Assembly Replacement, Remove the screws: step 1, image 1 of 1
      • Remove the two 1.9 mm Phillips screws securing the charging assembly to the bottom edge of the phone.
      Ask FixBot
    2. Google Pixel 3 Charging Assembly Replacement, Weaken the adhesive: step 2, image 1 of 1
      • Apply a heated iOpener to the bottom edge of the phone for a minute to loosen the adhesive holding the charging assembly in place.
      Ask FixBot
    3. Google Pixel 3 Charging Assembly Replacement, Loosen the charging assembly cable: step 3, image 1 of 3 Google Pixel 3 Charging Assembly Replacement, Loosen the charging assembly cable: step 3, image 2 of 3 Google Pixel 3 Charging Assembly Replacement, Loosen the charging assembly cable: step 3, image 3 of 3
      • Insert an opening pick underneath the charging assembly's flex cable.
      • Slide the opening pick below the charging assembly to loosen it from the phone.
      Ask FixBot
    4. Google Pixel 3 Charging Assembly Replacement, Remove the charging assembly: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers or your fingers to remove the charging assembly.
      Ask FixBot
    5. Google Pixel 3 Charging Assembly Replacement: step 5, image 1 of 3 Google Pixel 3 Charging Assembly Replacement: step 5, image 2 of 3 Google Pixel 3 Charging Assembly Replacement: step 5, image 3 of 3
      • When you are installing a replacement assembly:
      • Be sure to remove all plastic liners from the assembly to expose the adhesive.
      • Line up the assembly's bottom left corner into place.
      • Carefully lay the rest of the assembly in place, making sure that the USB-C port is correctly seated in its respective cutout.
      • Use your fingers to press the assembly onto the frame.
      Ask FixBot
Repair didn’t go as planned? Check out our Google Pixel 3 Answers community for troubleshooting help.
Arthur Shi
350,827 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 12
All Time: 150
