The screen attaches to the underside of the logic board by a press connector, which you'll indirectly connect as you install the board. Follow the next few steps carefully to ensure this connects properly.
Insert the bottom edge of the logic board at a shallow angle into the frame so the USB-C port presses snugly against its frame cutout.
Use a Torx Plus 3IP screwdriver to install the two 2.9 mm‑long logic board screws:
One at the top near the front camera
One near the bottom-right corner
Use a spudger or your finger to align and press the front camera into its cutout.
