Google Pixel 10a Battery Reconnect
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Google Pixel 10a Battery Reconnect, Connect the battery: step 1, image 1 of 2 Google Pixel 10a Battery Reconnect, Connect the battery: step 1, image 2 of 2
      • Use your finger to align and press the battery press connector over its socket.
      • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    2. Google Pixel 10a Battery Reconnect, Install the battery connector cover: step 2, image 1 of 2 Google Pixel 10a Battery Reconnect, Install the battery connector cover: step 2, image 2 of 2
      • Hook the left edge of the battery connector cover in place, then lay the cover down flat.
      Ask FixBot
    3. Google Pixel 10a Battery Reconnect: step 3, image 1 of 1
      • Use a Torx Plus 3IP screwdriver to install the 1.9 mm‑long battery connector cover screw.
      Ask FixBot
Arthur Shi
350,850 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 75
