Google Home Sound Driver Replacement
  1. Google Home Sound Driver Replacement, Interconnect Cable: step 1, image 1 of 3 Google Home Sound Driver Replacement, Interconnect Cable: step 1, image 2 of 3 Google Home Sound Driver Replacement, Interconnect Cable: step 1, image 3 of 3
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
  2. Google Home Sound Driver Replacement: step 2, image 1 of 1
    Tool used on this step:
    Buy
    • Carefully remove the interconnect cable using a pair of tweezers.
  3. Google Home Sound Driver Replacement, Mute Button Switch: step 3, image 1 of 2 Google Home Sound Driver Replacement, Mute Button Switch: step 3, image 2 of 2
    • Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
  4. Google Home Sound Driver Replacement: step 4, image 1 of 2 Google Home Sound Driver Replacement: step 4, image 2 of 2
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws.
    • Remove the panel and the mute button switch. If done correctly you should now be able to see the device’s guitar-shaped motherboard.
  5. Google Home Sound Driver Replacement, Motherboard: step 5, image 1 of 2 Google Home Sound Driver Replacement, Motherboard: step 5, image 2 of 2
    • Disconnect the foam-padded, red and black cable that connects the motherboard to the sound driver, by squeezing and pulling on the tab
    • Disconnect the orange interconnect cable that connects the bottom of the device to the motherboard by pulling straight out on the orange tab.
  6. Google Home Sound Driver Replacement: step 6, image 1 of 2 Google Home Sound Driver Replacement: step 6, image 2 of 2
    • Using a Torx T6 screwdriver head, unscrew the five silver 1.7mm Torx screws keeping the motherboard in place.
    • Remove the motherboard.
  7. Google Home Sound Driver Replacement, Sound Driver: step 7, image 1 of 2 Google Home Sound Driver Replacement, Sound Driver: step 7, image 2 of 2
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws on the bottom of the device.
    • For this step you will need a T6 screwdriver with an extra long head to reach the screws.
  8. Google Home Sound Driver Replacement: step 8, image 1 of 2 Google Home Sound Driver Replacement: step 8, image 2 of 2
    • Using a Torx T6 screwdriver head, unscrew the six black 1.7mm Torx screws on the side of the device.
  9. Google Home Sound Driver Replacement: step 9, image 1 of 2 Google Home Sound Driver Replacement: step 9, image 2 of 2
    • Pull apart the black casing to reveal the sound driver.
    • Remove the sound driver.
Gabe Hyun
826 Reputation
4 Guides authored
Cal Poly, Team S24-G11, Maness Spring 2018 Member of Cal Poly, Team S24-G11, Maness Spring 2018
CPSU-MANESS-S18S24G11
4 Members
5 Guides authored
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 42
All Time: 2,082
