Introduction
In this guide, you will be separating the motherboard from the Midframe of the GoPro Hero5 Black. The GoPro Hero5 Black is waterproofed with plenty of adhesives. By completing this guide, you will have to remove the adhesive and your GoPro will no longer be waterproof.
While pressing the button on the bottom of the GoPro, slide the battery door to the side to pop it open.
Refer to the iOpener instructions for how to heat up and use the iOpener.
Apply the heated iOpener to the front of the GoPro for a few minutes to melt the adhesive under the faceplate.
Use the flat end of a spudger to pry the three ribbon cables connected to the side of the motherboard.
Use the flat end of the spudger to pry the battery housing power cable straight up from its socket on the motherboard.
Use the flat end of the spudger to pry the black cover plate straight up from its socket on the motherboard.
Use the tweezers to pull the ribbon cable connector out of its white socket on the charging assembly board.
Use the flat end of the spudger to pry the charging port ribbon cable connector straight up from its socket on the motherboard.
Use the flat end of the spudger to pry the lens assembly ribbon cable connector straight up from its socket on the motherboard.
Use the flat end of the spudger to pry the LCD screen ribbon cable connector straight up from its socket on the motherboard.
