Gateway MS2370 Screen Replacement
  1. Gateway MS2370 Screen Replacement, Battery: step 1, image 1 of 1
    • Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
  2. Gateway MS2370 Screen Replacement: step 2, image 1 of 1
    • Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
  3. Gateway MS2370 Screen Replacement: step 3, image 1 of 1
    • Pull the battery from the laptop to remove it.
  4. Gateway MS2370 Screen Replacement, Screen: step 4, image 1 of 1
    • Using the pointed tweezers, remove plastic circles that are stuck onto the back of the laptop’s hinges.
    • These plastic circles are stuck inside the hole with adhesive and might require a significant amount of force.
  5. Gateway MS2370 Screen Replacement: step 5, image 1 of 2 Gateway MS2370 Screen Replacement: step 5, image 2 of 2
    • Unscrew both of the 3mm Phillips 01 screws on both hinges using the matching screwdriver.
  6. Gateway MS2370 Screen Replacement: step 6, image 1 of 1
    • Take the plastic spudger and pull up the tabs on all four sides of the screen molding.
  7. Gateway MS2370 Screen Replacement: step 7, image 1 of 1
    • Carefully remove the screen molding. Be aware that the screen molding will not come out all the way.
  8. Gateway MS2370 Screen Replacement: step 8, image 1 of 1
    • Unscrew the four 3mm inch Phillips 01 screws on the screen bracket.
  9. Gateway MS2370 Screen Replacement: step 9, image 1 of 3 Gateway MS2370 Screen Replacement: step 9, image 2 of 3 Gateway MS2370 Screen Replacement: step 9, image 3 of 3
    • Peel up the tape over the connector and unplug the screen from the laptop.
  10. Gateway MS2370 Screen Replacement: step 10, image 1 of 2 Gateway MS2370 Screen Replacement: step 10, image 2 of 2
    • Slowly remove the screen from the laptop.
Mathieu Bolduc-Clayton
518 Reputation
4 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 663
