Gateway LT2514u Battery Replacement
  1. Gateway LT2514u Battery Replacement, Battery: step 1, image 1 of 2 Gateway LT2514u Battery Replacement, Battery: step 1, image 2 of 2
    • With the netbook's lid closed flip it over and slide the latch located on the upper left hand side of the netbook to the left.
    • You should see an orange indicator when the battery is unlocked.
  2. Gateway LT2514u Battery Replacement: step 2, image 1 of 2 Gateway LT2514u Battery Replacement: step 2, image 2 of 2
    • In the upper right-hand corner of the netbook, slide and hold the switch to the right.
    • Use your other hand to slide out the battery.
    • If the release switch in the upper right-hand area is missing, you can still remove the battery by following Step 3. Otherwise, skip it.
  3. Gateway LT2514u Battery Replacement: step 3, image 1 of 3 Gateway LT2514u Battery Replacement: step 3, image 2 of 3 Gateway LT2514u Battery Replacement: step 3, image 3 of 3
    • If the release switch in the upper right-hand area is missing, insert a slender tool (we used tweezers) into the left side of the smaller hole.
    • Slide and hold the tweezers to the right and use your other hand to slide the battery out.
Brian Garver
839 Reputation
6 Guides authored
USF Tampa, Team 3-2, Sullivan Fall 2016 Member of USF Tampa, Team 3-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G2
3 Members
12 Guides authored
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 330
