Fast Fix Ceramic Briquettes in a Gas Grill Replacement
  1. Fast Fix Ceramic Briquettes in a Gas Grill Replacement, Remove Grill Plate: step 1, image 1 of 3 Fast Fix Ceramic Briquettes in a Gas Grill Replacement, Remove Grill Plate: step 1, image 2 of 3 Fast Fix Ceramic Briquettes in a Gas Grill Replacement, Remove Grill Plate: step 1, image 3 of 3
    • Carefully lift grill plate located above briquettes
  2. Fast Fix Ceramic Briquettes in a Gas Grill Replacement, Remove Ceramic Briquette Casing Panel: step 2, image 1 of 3 Fast Fix Ceramic Briquettes in a Gas Grill Replacement, Remove Ceramic Briquette Casing Panel: step 2, image 2 of 3 Fast Fix Ceramic Briquettes in a Gas Grill Replacement, Remove Ceramic Briquette Casing Panel: step 2, image 3 of 3
    • Carefully remove entire ceramic briquette casing from above the stainless steal burner.
  3. Fast Fix Ceramic Briquettes in a Gas Grill Replacement, Unscrew Briquette Casing: step 3, image 1 of 3 Fast Fix Ceramic Briquettes in a Gas Grill Replacement, Unscrew Briquette Casing: step 3, image 2 of 3 Fast Fix Ceramic Briquettes in a Gas Grill Replacement, Unscrew Briquette Casing: step 3, image 3 of 3
    • Locate the six screws located on top of the ceramic briquette casing and unscrew them using your phillips head screwdriver.
  4. Fast Fix Ceramic Briquettes in a Gas Grill Replacement, Unscrew Washers: step 4, image 1 of 3 Fast Fix Ceramic Briquettes in a Gas Grill Replacement, Unscrew Washers: step 4, image 2 of 3 Fast Fix Ceramic Briquettes in a Gas Grill Replacement, Unscrew Washers: step 4, image 3 of 3
    • Using your hands, gently unscrew washers from the back of the casing.
  5. Fast Fix Ceramic Briquettes in a Gas Grill Replacement, Separate Two Pieces: step 5, image 1 of 3 Fast Fix Ceramic Briquettes in a Gas Grill Replacement, Separate Two Pieces: step 5, image 2 of 3 Fast Fix Ceramic Briquettes in a Gas Grill Replacement, Separate Two Pieces: step 5, image 3 of 3
    • Separate the front and back metal casings surrounding the briquettes.
  6. Fast Fix Ceramic Briquettes in a Gas Grill Replacement, Remove Old Briquettes: step 6, image 1 of 1
    • Take out old and use briquettes and dispose of them. (They will probably be black and tarnished)
  7. Fast Fix Ceramic Briquettes in a Gas Grill Replacement, Replace With New Ones: step 7, image 1 of 1
    • Take 16 new ceramic briquettes out and carefully align them inside of the casing. Be sure to pay attention to where you place them, as some should be straight and some diagonal for the casing to close back correctly.
emma
173 Reputation
1 Guide authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 64
All Time: 3,589
