Gas Grill Ceramic Briquettes Replacement
  1. Gas Grill Ceramic Briquettes Replacement, Remove Grill Plate: step 1, image 1 of 3 Gas Grill Ceramic Briquettes Replacement, Remove Grill Plate: step 1, image 2 of 3 Gas Grill Ceramic Briquettes Replacement, Remove Grill Plate: step 1, image 3 of 3
    • Carefully lift grill plate located above briquettes
    • Make sure the gas grill is off and the propane is turned off before removing the grill plate
  2. Gas Grill Ceramic Briquettes Replacement, Remove Ceramic Briquette Casing Panel: step 2, image 1 of 3 Gas Grill Ceramic Briquettes Replacement, Remove Ceramic Briquette Casing Panel: step 2, image 2 of 3 Gas Grill Ceramic Briquettes Replacement, Remove Ceramic Briquette Casing Panel: step 2, image 3 of 3
    • Carefully remove entire ceramic briquette casing from above the stainless steel burner.
  3. Gas Grill Ceramic Briquettes Replacement, Unscrew Briquette Casing: step 3, image 1 of 3 Gas Grill Ceramic Briquettes Replacement, Unscrew Briquette Casing: step 3, image 2 of 3 Gas Grill Ceramic Briquettes Replacement, Unscrew Briquette Casing: step 3, image 3 of 3
    • Locate the six screws located on top of the ceramic briquette casing and unscrew them using your phillips head screwdriver.
    • A small container is recommended to keep the screws together
  4. Gas Grill Ceramic Briquettes Replacement, Unscrew Washers: step 4, image 1 of 3 Gas Grill Ceramic Briquettes Replacement, Unscrew Washers: step 4, image 2 of 3 Gas Grill Ceramic Briquettes Replacement, Unscrew Washers: step 4, image 3 of 3
    • Using your hands, gently unscrew washers from the back of the casing.
    • A small container is recommended to keep the washers together
  5. Gas Grill Ceramic Briquettes Replacement, Separate Two Pieces: step 5, image 1 of 3 Gas Grill Ceramic Briquettes Replacement, Separate Two Pieces: step 5, image 2 of 3 Gas Grill Ceramic Briquettes Replacement, Separate Two Pieces: step 5, image 3 of 3
    • Separate the front and back metal casings surrounding the briquettes.
  6. Gas Grill Ceramic Briquettes Replacement, Remove Old Briquettes: step 6, image 1 of 1
    • Take out old and used briquettes and dispose of them. (They will probably be black and tarnished)
  7. Gas Grill Ceramic Briquettes Replacement, Replace With New Ones: step 7, image 1 of 1
    • Take 16 new ceramic briquettes out and carefully align them inside the casing.
    • Be sure to pay attention to where you place them, as some should be straight and some diagonal for the casing to close back correctly.
3 other people completed this guide.
emma
173 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 40
All Time: 3,486
