Garmin nuviCam LMTHD Battery Replacement
  1. Garmin nuviCam LMTHD Battery Replacement, Screen: step 1, image 1 of 2 Garmin nuviCam LMTHD Battery Replacement, Screen: step 1, image 2 of 2
    • Remove the four 6.9 mm black screws using the T6 screw bit.
  2. Garmin nuviCam LMTHD Battery Replacement: step 2, image 1 of 2 Garmin nuviCam LMTHD Battery Replacement: step 2, image 2 of 2
    • Pry the device open using a plastic opening tool.
    • We suggest starting from the dash camera side for easier opening
    • You may have to use a little force, the screen is hard to remove.
  3. Garmin nuviCam LMTHD Battery Replacement: step 3, image 1 of 1
    • Disconnect the black and red wire from the screen.
  4. Garmin nuviCam LMTHD Battery Replacement: step 4, image 1 of 2 Garmin nuviCam LMTHD Battery Replacement: step 4, image 2 of 2
    • Disconnect the orange strip by flipping up the connector with a plastic opening tool and sliding the cable out.
  5. Garmin nuviCam LMTHD Battery Replacement, Battery: step 5, image 1 of 1
    • Locate the white box in your device which is the battery.
  6. Garmin nuviCam LMTHD Battery Replacement: step 6, image 1 of 1
    • Disconnect battery from device pulling the green, red, and black wires from motherboard.
  7. Garmin nuviCam LMTHD Battery Replacement: step 7, image 1 of 1
    • Disconnect orange cable strip laying across battery by sliding it out of connector .
    • It may be at your benefit to use tweezers. It will be easier to reconnect the orange ribbon later with this tool.
  8. Garmin nuviCam LMTHD Battery Replacement: step 8, image 1 of 1
    • Pry battery out of device.
    • Battery is glued into device, so it may be difficult to remove.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 16
All Time: 4,936
