Garmin Nuvi 255W Battery Replacement
  1. Garmin Nuvi 255W Battery Replacement, Power Button: step 1, image 1 of 1
    • Remove the barcode sticker at the bottom of the device.
  2. Garmin Nuvi 255W Battery Replacement: step 2, image 1 of 1
    • Remove two 8.4 mm T5 screws from the bottom of the device.
  3. Garmin Nuvi 255W Battery Replacement: step 3, image 1 of 2 Garmin Nuvi 255W Battery Replacement: step 3, image 2 of 2
    • Using a plastic opening tool, carefully pry open the device.
    • Open the device carefully, making sure not to damage the gold ribbon cable that connects the screen to the motherboard.
  4. Garmin Nuvi 255W Battery Replacement: step 4, image 1 of 2 Garmin Nuvi 255W Battery Replacement: step 4, image 2 of 2
    • Remove the power button.
  5. Garmin Nuvi 255W Battery Replacement, Battery: step 5, image 1 of 1
    • Unscrew the four 6.70 mm screws holding the motherboard in place using a philips #0 screw driver.
  6. Garmin Nuvi 255W Battery Replacement: step 6, image 1 of 2 Garmin Nuvi 255W Battery Replacement: step 6, image 2 of 2
    • Lift up the motherboard.
    • Carefully disconnect the battery and motherboard. Slowly wiggling the connection makes it easier to disconnect the battery from the motherboard.
  7. Garmin Nuvi 255W Battery Replacement: step 7, image 1 of 2 Garmin Nuvi 255W Battery Replacement: step 7, image 2 of 2
    • Using the plastic opening tool as a wedge, pry the battery from the case. This can be fairly tough as the battery is glued to the case. Don't be afraid to use force and some good leverage.
Timothy
73 Reputation
3 Guides authored
Cal Poly, Team 9-3, Regan Winter 2012 Member of Cal Poly, Team 9-3, Regan Winter 2012
CPSU-REGAN-W12S9G3
5 Members
4 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 39
All Time: 26,705
