Introduction
Use this guide to replace the battery in the Garmin Nuvi 255W.
Unscrew the four 6.70 mm screws holding the motherboard in place using a philips #0 screw driver.
Lift up the motherboard.
Carefully disconnect the battery and motherboard. Slowly wiggling the connection makes it easier to disconnect the battery from the motherboard.
Using the plastic opening tool as a wedge, pry the battery from the case. This can be fairly tough as the battery is glued to the case. Don't be afraid to use force and some good leverage.
