Introduction
Garmin Edge 800 have a bad habit of not connecting to PC (not recognized by PC) or always starting to a service mode or diagnostic screen (this was the problem with my Edge 800).
This problem typically starts occurring after the USB port has been exposed to moisture. It first manifests as problem with connection to PC, but later worsens and the device always boots up to a diagnostic screen.
First step should be to clean the USB contacts from the outside. If that doesn't help, you will need to open the device and clean the contacts inside.
In this guide I will show you what is causing this malfunction and how to fix this problem.
Disassemble your Garmin until you have the bottom half of the case like in the picture (if you're not sure how, look at youtube for a video on how to replace battery)
It requires the correct size of Torx for the screws
The main circuit board and battery is easily disconnected from the little board which is part of the bottom half of the case
You may keep the processor board and LCD together
Desolder the 2 speaker wires from the circuit board (take a photo before you do so)
Scrape away the sealant and remove the small circuit board with the USB port and SD card from the bottom half of the case
In next step you will work only with the small USB / SD circuit board
The actual cause why the USB stops working is that the tiny pins on the back side of the USB plug corrode
As the wires corrode, they enlarge their volume, causing short between the wires
I found it when I noticed in the service screen that the USB input voltage measured only about 3V
To remove the corroded metal causing the short, take a sharp tool (could be sharp pointed tweezers or a needle) and scrape away the oxidized material from between the leads, as indicated by red lines in the picture
brass wire brush or steel wool could also be helpful
Apply plastidip on the pins to protect them from environment and to prevent them from creating short again
After you put the USB / SD circuit board back into the bottom half of case, seal it with something like plastidip or silicone sealant.
Resolder the speaker wires
Clean the connectors with 100% alcohol or lighter fluid (naphta) to ensure good contact
Then reassemble the whole unit
Be gentle when tightening the torx screws, as the thread in plastic is quite easy to strip with too much torque (If you're curious how I know it, look closely at the pictures :)
