Garmin Edge 800 USB not connecting to PC
  1. Garmin Edge 800 USB not connecting to PC, Open the device: step 1, image 1 of 1
    • Disassemble your Garmin until you have the bottom half of the case like in the picture (if you're not sure how, look at youtube for a video on how to replace battery)
    • It requires the correct size of Torx for the screws
    • The main circuit board and battery is easily disconnected from the little board which is part of the bottom half of the case
    • You may keep the processor board and LCD together
  2. Garmin Edge 800 USB not connecting to PC, Remove small circuit board: step 2, image 1 of 2 Garmin Edge 800 USB not connecting to PC, Remove small circuit board: step 2, image 2 of 2
    • Desolder the 2 speaker wires from the circuit board (take a photo before you do so)
    • Scrape away the sealant and remove the small circuit board with the USB port and SD card from the bottom half of the case
    • In next step you will work only with the small USB / SD circuit board
  3. Garmin Edge 800 USB not connecting to PC, Fix the cause of the problem: step 3, image 1 of 1
    • The actual cause why the USB stops working is that the tiny pins on the back side of the USB plug corrode
    • As the wires corrode, they enlarge their volume, causing short between the wires
    • I found it when I noticed in the service screen that the USB input voltage measured only about 3V
    • To remove the corroded metal causing the short, take a sharp tool (could be sharp pointed tweezers or a needle) and scrape away the oxidized material from between the leads, as indicated by red lines in the picture
    • brass wire brush or steel wool could also be helpful
    • Apply plastidip on the pins to protect them from environment and to prevent them from creating short again
    • After you put the USB / SD circuit board back into the bottom half of case, seal it with something like plastidip or silicone sealant.
    • Resolder the speaker wires
    • Clean the connectors with 100% alcohol or lighter fluid (naphta) to ensure good contact
    • Then reassemble the whole unit
    • Be gentle when tightening the torx screws, as the thread in plastic is quite easy to strip with too much torque (If you're curious how I know it, look closely at the pictures :)
Ondrej Pok
451 Reputation
2 Guides authored
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 68
All Time: 9,062
