Garmin DriveSmart 71 EX Screen Replacement
    1. Garmin DriveSmart 71 EX Screen Replacement, Case: step 1, image 1 of 1
      • Unplug and power off the device.
      Ask FixBot
    2. Garmin DriveSmart 71 EX Screen Replacement: step 2, image 1 of 1
      • Remove the four 5 mm T5 Torx screws securing the rear case.
      Ask FixBot
    3. Garmin DriveSmart 71 EX Screen Replacement: step 3, image 1 of 3 Garmin DriveSmart 71 EX Screen Replacement: step 3, image 2 of 3 Garmin DriveSmart 71 EX Screen Replacement: step 3, image 3 of 3
      • Insert an opening pick into the seam between the front and back cover.
      • Carefully slide the opening pick around the perimeter of the device to release the clips securing the front and rear case.
      • Open the case with care not to strain the display ribbon cable or the microphone cable.
      • You may hear small snapping sounds as the clips release. Don't worry, this is normal.
      Ask FixBot
    1. Garmin DriveSmart 71 EX Screen Replacement, Screen: step 4, image 1 of 3 Garmin DriveSmart 71 EX Screen Replacement, Screen: step 4, image 2 of 3 Garmin DriveSmart 71 EX Screen Replacement, Screen: step 4, image 3 of 3
      • Carefully flip up the locking tab on the connector to release the display ribbon cable.
      • Gently slide the ribbon cable out out of its socket.
      Ask FixBot
    2. Garmin DriveSmart 71 EX Screen Replacement: step 5, image 1 of 3 Garmin DriveSmart 71 EX Screen Replacement: step 5, image 2 of 3 Garmin DriveSmart 71 EX Screen Replacement: step 5, image 3 of 3
      • Align the replacement screen with the device frame.
      • Reconnect the display ribbon cable securely and resecure the locking flap.
      • Press the screen into place.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Julien Bush
219 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 18
All Time: 146
