Garmin DriveSmart 71 EX Battery Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
6
Past 30 Days:
53
All Time:
213
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your Garmin DriveSmart 71 EX won’t power on or fails to hold a charge, a worn-out or disconnected battery may be the cause. This guide walks you through opening the device and replacing the internal battery. Handle the internal connectors and cables with care to prevent damage to the components during the repair process.
Tools
    1. Garmin DriveSmart 71 EX Battery Replacement, Case: step 1, image 1 of 1
      • Unplug and power off the device.
      Ask FixBot
    2. Garmin DriveSmart 71 EX Battery Replacement: step 2, image 1 of 1
      • Remove the four 5 mm T5 Torx screws securing the rear case.
      Ask FixBot
    3. Garmin DriveSmart 71 EX Battery Replacement: step 3, image 1 of 3 Garmin DriveSmart 71 EX Battery Replacement: step 3, image 2 of 3 Garmin DriveSmart 71 EX Battery Replacement: step 3, image 3 of 3
      • Insert an opening pick into the seam between the front and back cover.
      • Carefully slide the opening pick around the perimeter of the device to release the clips securing the front and rear case.
      • Open the case with care not to strain the display ribbon cable or the microphone cable.
      • You may hear small snapping sounds as the clips release. Don't worry, this is normal.
      Ask FixBot
    1. Garmin DriveSmart 71 EX Battery Replacement, Battery: step 4, image 1 of 2 Garmin DriveSmart 71 EX Battery Replacement, Battery: step 4, image 2 of 2
      • Use tweezers to disconnect the white battery cable connector from its motherboard socket.
      • Tweezers are optional. Do not use too much force to remove the wires if you are using your hands.
      Ask FixBot
    2. Garmin DriveSmart 71 EX Battery Replacement: step 5, image 1 of 2 Garmin DriveSmart 71 EX Battery Replacement: step 5, image 2 of 2
      • Use a plastic spudger to lift and remove the battery from the back cover.
      • Do not pull on the wires to remove the battery from the device. Take care not to bend, puncture, or twist the battery.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
SunnyD
185 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 53
All Time: 213
