Garmin Drive 61 LM Screen Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
64
All Time:
358
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your Garmin Drive 61 LM device is freezing or refusing to power on, utilize this guide to help replace the screen to get back to navigating.
Should the device suddenly freeze or refuse to power on, a symptom of these technical issues may lie with a malfunctioning screen that needs to be replaced.
Before utilizing this device guide, ensure the technical difficulties your Garmin Drive 61 LM is facing aligns with the symptoms for a faulty screen on the troubleshooting page: Garmin Drive 61 LM Freezing
Before beginning to replace the screen, ensure you have all of the correct tools and replacement parts. you will need a T5 screwdriver and a pry tool for taking apart the device. Replacement parts for the screen include a 6.1-inch color touchscreen (LCD + digitizer). If you have a 6.1-inch color touchscreen with dual orientation instead, that is sufficient enough.
Tools
    1. Garmin Drive 61 LM Screen Replacement, Battery: step 1, image 1 of 2 Garmin Drive 61 LM Screen Replacement, Battery: step 1, image 2 of 2
      • Place the device screen side down with the back screws facing up towards the ceiling.
      • Remove the four T5 Torx screws on the rear case.
      Ask FixBot
    2. Garmin Drive 61 LM Screen Replacement: step 2, image 1 of 3 Garmin Drive 61 LM Screen Replacement: step 2, image 2 of 3 Garmin Drive 61 LM Screen Replacement: step 2, image 3 of 3
      • Insert an opening tool into the seam between the rear case and screen.
      • Pry around the perimeter.
      • Pull the rear case and screen apart, with care not to strain the attached ribbon cable.
      • Set the screen next to the rear case.
      Ask FixBot
    3. Garmin Drive 61 LM Screen Replacement: step 3, image 1 of 3 Garmin Drive 61 LM Screen Replacement: step 3, image 2 of 3 Garmin Drive 61 LM Screen Replacement: step 3, image 3 of 3
      • Use a T5 Torx screwdriver to remove the five screws securing the motherboard.
      Ask FixBot
    4. Garmin Drive 61 LM Screen Replacement: step 4, image 1 of 3 Garmin Drive 61 LM Screen Replacement: step 4, image 2 of 3 Garmin Drive 61 LM Screen Replacement: step 4, image 3 of 3
      • Be gentle when removing as these are more delicate parts of your device.
      • Use an opening tool to dislodge the speaker and battery.
      Ask FixBot
    5. Garmin Drive 61 LM Screen Replacement: step 5, image 1 of 2 Garmin Drive 61 LM Screen Replacement: step 5, image 2 of 2
      • Flip the motherboard upside down and use your fingernails to disconnect the battery connector.
      Ask FixBot
    6. Garmin Drive 61 LM Screen Replacement: step 6, image 1 of 1
      • Stick the new battery and speaker back onto the plastic.
      • Reconnect the speaker and battery.
      Ask FixBot
    1. Garmin Drive 61 LM Screen Replacement, Screen: step 7, image 1 of 3 Garmin Drive 61 LM Screen Replacement, Screen: step 7, image 2 of 3 Garmin Drive 61 LM Screen Replacement, Screen: step 7, image 3 of 3
      • Disconnect the screen ribbon cable.
      • Use an opening tool to gently separate the screen from frame.
      Ask FixBot
    2. Garmin Drive 61 LM Screen Replacement: step 8, image 1 of 2 Garmin Drive 61 LM Screen Replacement: step 8, image 2 of 2
      • Reconnect the display flex cable to the new screen.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Bailey Hodge
215 Reputation
1 Guide authored
Texas Tech, Team 45-2, Weston Fall 2025 Member of Texas Tech, Team 45-2, Weston Fall 2025
TTU-WESTON-F25S45G2
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 64
All Time: 358
