Introduction
If your Garmin Drive 61 LM device is freezing or refusing to power on, utilize this guide to help replace the faulty battery to get back to navigating.
The battery of the Garmin Drive 61 LM works consistently to power the device. Should the screen suddenly freeze or refuse to power on, a symptom of these technical issues may lie with a faulty battery that needs to be replaced.
Before utilizing this device guide, ensure the technical difficulties your Garmin Drive 61 LM is facing aligns with the symptoms for battery trouble on the troubleshooting page: Garmin Drive 61 LM Freezing
Before beginning to replace the battery, ensure that a 3.7 V nominal with a 1100 mAh capacity is required in order to properly fix the device. Also procure a 1 x Coin, flat head screwdriver, or pry tool and 1 x 2mm Hex Screwdriver.
Place the device screen side down with the back screws facing up towards the ceiling.
Remove the four T5 Torx screws on the rear case.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
