Garmin Drive 50 LM Screen Replacement
    1. Garmin Drive 50 LM Screen Replacement, Screen Replacement: step 1, image 1 of 3 Garmin Drive 50 LM Screen Replacement, Screen Replacement: step 1, image 2 of 3 Garmin Drive 50 LM Screen Replacement, Screen Replacement: step 1, image 3 of 3
      • Flip the device over to its back.
      • Use a T5 Torx screwdriver to remove the four 5.8 mm screws as shown above.
      Ask FixBot
    2. Garmin Drive 50 LM Screen Replacement: step 2, image 1 of 2 Garmin Drive 50 LM Screen Replacement: step 2, image 2 of 2
      • Insert an opening tool into the seam between the case and chassis. Pry open the corner of the screen and work down the length of the device.
      • Repeat the same for all other sides of the device until it is out of the case.
      Ask FixBot
    3. Garmin Drive 50 LM Screen Replacement: step 3, image 1 of 1
      • Gently set down the side with the screen.
      • Be careful as to not rip the orange cord connecting the screen to the motherboard.
      Ask FixBot
    4. Garmin Drive 50 LM Screen Replacement: step 4, image 1 of 3 Garmin Drive 50 LM Screen Replacement: step 4, image 2 of 3 Garmin Drive 50 LM Screen Replacement: step 4, image 3 of 3
      • Look for the brown latch holding the orange cord down on the motherboard and with tweezers, flip the latch up.
      • Gently pull the orange cord out of the motherboard.
      Ask FixBot
    5. Garmin Drive 50 LM Screen Replacement: step 5, image 1 of 2 Garmin Drive 50 LM Screen Replacement: step 5, image 2 of 2
      • With your opening tool, pop out the original screen from the case.
      • You should hear four clicks, one from each of the prongs holding the screen in.
      Ask FixBot
    6. Garmin Drive 50 LM Screen Replacement: step 6, image 1 of 1
      • Replace damaged or faulty screen with new one.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 25
All Time: 234
