Garmin Drive 50 LM Battery Replacement
    1. Garmin Drive 50 LM Battery Replacement, Garmin Drive 50 LM Case Removal: step 1, image 1 of 3 Garmin Drive 50 LM Battery Replacement, Garmin Drive 50 LM Case Removal: step 1, image 2 of 3 Garmin Drive 50 LM Battery Replacement, Garmin Drive 50 LM Case Removal: step 1, image 3 of 3
      • Use a T5 Torx screwdriver to remove the four 9 mm-long screws securing the case.
      Ask FixBot
    2. Garmin Drive 50 LM Battery Replacement: step 2, image 1 of 2 Garmin Drive 50 LM Battery Replacement: step 2, image 2 of 2
      • Insert an opening tool into the seam between the case and the chassis.
      • Pry around the perimeter of the device until the case releases.
      • It is recommended to work along the length of the device first, then the width.
      Ask FixBot
    3. Garmin Drive 50 LM Battery Replacement: step 3, image 1 of 1
      • Once open, set the screen down at an offset to be able to see the yellow cable.
      Ask FixBot
    4. Garmin Drive 50 LM Battery Replacement: step 4, image 1 of 3 Garmin Drive 50 LM Battery Replacement: step 4, image 2 of 3 Garmin Drive 50 LM Battery Replacement: step 4, image 3 of 3
      • With tweezers, flip up the brown locking flap to release the ribbon cable.
      • Gently disconnect the yellow ribbon cable.
      Ask FixBot
    1. Garmin Drive 50 LM Battery Replacement, Battery Replacement: step 5, image 1 of 3 Garmin Drive 50 LM Battery Replacement, Battery Replacement: step 5, image 2 of 3 Garmin Drive 50 LM Battery Replacement, Battery Replacement: step 5, image 3 of 3
      • Locate the two white plugs on the side of the mother board.
      • With your tweezers, gently pull on the most right plug until it disconnected from the mother board.
      • The battery might be slightly sticky due to adhesive that was holding it down.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Mikel
73 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 92
All Time: 423
