GameSir X2 Type-C Left Joystick Replacement
  1. GameSir X2 Type-C Left Joystick Replacement, Back Cover: step 1, image 1 of 2 GameSir X2 Type-C Left Joystick Replacement, Back Cover: step 1, image 2 of 2
    • Turn the device so the back faces you.
  2. GameSir X2 Type-C Left Joystick Replacement: step 2, image 1 of 2 GameSir X2 Type-C Left Joystick Replacement: step 2, image 2 of 2
    • Remove the eight 6 mm T6 Torx screws.
  3. GameSir X2 Type-C Left Joystick Replacement: step 3, image 1 of 1
    • Use a straight edge to remove the rubber pad on the front of the device.
  4. GameSir X2 Type-C Left Joystick Replacement: step 4, image 1 of 2 GameSir X2 Type-C Left Joystick Replacement: step 4, image 2 of 2
    • Remove the four 4.5 mm screws with a Phillips #000 screwdriver.
  5. GameSir X2 Type-C Left Joystick Replacement: step 5, image 1 of 2 GameSir X2 Type-C Left Joystick Replacement: step 5, image 2 of 2
    • Use a straight edge to pry open the controller, following the seam on the controller.
    • Some force is necessary, but be careful not to damage any of the clips holding the controller together.
  6. GameSir X2 Type-C Left Joystick Replacement, Left Joystick: step 6, image 1 of 3 GameSir X2 Type-C Left Joystick Replacement, Left Joystick: step 6, image 2 of 3 GameSir X2 Type-C Left Joystick Replacement, Left Joystick: step 6, image 3 of 3
    • Pull the joystick cap out of its socket.
  7. GameSir X2 Type-C Left Joystick Replacement: step 7, image 1 of 3 GameSir X2 Type-C Left Joystick Replacement: step 7, image 2 of 3 GameSir X2 Type-C Left Joystick Replacement: step 7, image 3 of 3
    • Remove the four 6 mm screws using a Phillips #00 screwdriver.
    • Remove the single 7.5 mm screw using a Phillips #00 screwdriver.
  8. GameSir X2 Type-C Left Joystick Replacement: step 8, image 1 of 2 GameSir X2 Type-C Left Joystick Replacement: step 8, image 2 of 2
    • Pull out the left trigger.
  9. GameSir X2 Type-C Left Joystick Replacement: step 9, image 1 of 1
    • Pull out the left joystick.
  10. GameSir X2 Type-C Left Joystick Replacement: step 10, image 1 of 3 GameSir X2 Type-C Left Joystick Replacement: step 10, image 2 of 3 GameSir X2 Type-C Left Joystick Replacement: step 10, image 3 of 3
    • Flip up the black ZIF locking flap to disconnect the ribbon cable.
Guillermo Lopez
133 Reputation
1 Guide authored
1 Guide Comment
Nice guide, but where does one procure a replacement thumbstick assembly?
Rens van den Heuvel - Reply
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 50
All Time: 1,083
