GameSir X2 Pro Rail Spring Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
29
Past 30 Days:
86
All Time:
308
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Difficult
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide demonstrates how to replace the rail springs in your GameSir X2 Pro controller. Over time, the internal springs that provide tension to the expandable rails can wear out or lose their elasticity, leading to a loose or inconsistent fit when holding your device.
Replacing the rail springs can restore proper tension and improve the controller’s overall stability and feel.
Warning: This guide requires the use of a soldering iron. If you are new to soldering or would like a refresher, refer to the How to Solder and Desolder Connections guide before beginning.
Use caution when working with a soldering iron, as it becomes extremely hot and can easily cause burns or melt plastic components. To reduce exposure to soldering fumes, perform all soldering and desoldering work in a well-ventilated area.
Tools
    1. GameSir X2 Pro Rail Spring Replacement, Rail Spring: step 1, image 1 of 1
      • Use a Jimmy to remove the rubber pad on the front of the device.
      Ask FixBot
    2. GameSir X2 Pro Rail Spring Replacement: step 2, image 1 of 2 GameSir X2 Pro Rail Spring Replacement: step 2, image 2 of 2
      • Remove the four 4.5 mm screws under the rubber pad with a Phillips #000 screwdriver.
      Ask FixBot
    3. GameSir X2 Pro Rail Spring Replacement: step 3, image 1 of 2 GameSir X2 Pro Rail Spring Replacement: step 3, image 2 of 2
      • Remove the eight 6 mm T6 Torx screws from the back of the device.
      Ask FixBot
    4. GameSir X2 Pro Rail Spring Replacement: step 4, image 1 of 3 GameSir X2 Pro Rail Spring Replacement: step 4, image 2 of 3 GameSir X2 Pro Rail Spring Replacement: step 4, image 3 of 3
      • Use a Jimmy to pry open the controller, following the seam on the controller.
      • Some force is necessary, but be careful not to damage any of the clips holding the controller together.
      Ask FixBot
    5. GameSir X2 Pro Rail Spring Replacement: step 5, image 1 of 3 GameSir X2 Pro Rail Spring Replacement: step 5, image 2 of 3 GameSir X2 Pro Rail Spring Replacement: step 5, image 3 of 3
      • Remove the six 4.5 mm screws from the back panel with a Phillips #000 screwdriver.
      Ask FixBot
    6. GameSir X2 Pro Rail Spring Replacement: step 6, image 1 of 2 GameSir X2 Pro Rail Spring Replacement: step 6, image 2 of 2
      • Use a T6 Torx screwdriver to remove the eight 6.0 mm screws from the ends of the springs.
      Ask FixBot
    7. GameSir X2 Pro Rail Spring Replacement: step 7, image 1 of 3 GameSir X2 Pro Rail Spring Replacement: step 7, image 2 of 3 GameSir X2 Pro Rail Spring Replacement: step 7, image 3 of 3
      • Heat the solder points with a soldering iron and carefully remove the springs from the wires.
      • Be very careful when using the soldering iron. It gets extremely hot and can easily burn your skin or melt the plastic controller.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Sean Brady
653 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 29
Past 30 Days: 86
All Time: 308
