GameSir G7 SE Trigger Replacement
    1. GameSir G7 SE Trigger Replacement, Trigger: step 1, image 1 of 1
      • Remove the faceplate by prying open the cover with an opening tool.
      Ask FixBot
    2. GameSir G7 SE Trigger Replacement: step 2, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the six 9.2 mm screws around the face of the controller.
      Ask FixBot
    3. GameSir G7 SE Trigger Replacement: step 3, image 1 of 1
      • Detach the interior faceplate using the opening tool.
      Ask FixBot
    4. GameSir G7 SE Trigger Replacement: step 4, image 1 of 1
      • Remove each of the three 4 mm-long screws securing the daughterboard using a Phillips #0 screwdriver.
      Ask FixBot
    5. GameSir G7 SE Trigger Replacement: step 5, image 1 of 1
      • Use an opening tool to flip up the locking flap securing the daughterboard ribbon cable.
      • Disconnect the ribbon cable.
      Ask FixBot
    6. GameSir G7 SE Trigger Replacement: step 6, image 1 of 1
      • Disconnect both rumble motors from the motherboard on each side of the controller using tweezers.
      Ask FixBot
    7. GameSir G7 SE Trigger Replacement: step 7, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the four 4 mm-long screws securing the motherboard.
      Ask FixBot
    8. GameSir G7 SE Trigger Replacement: step 8, image 1 of 1
      • Take the motherboard out by lifting it up.
      Ask FixBot
    9. GameSir G7 SE Trigger Replacement: step 9, image 1 of 1
      • Disconnect the wire connecting the triggers to the motherboard.
      Ask FixBot
    10. GameSir G7 SE Trigger Replacement: step 10, image 1 of 1
      • Remove the three 4 mm-long screws connecting the triggers to the motherboard using a Phillips #0 screwdriver.
      • Remove the trigger.
      • Repeat Steps 9 and 10 for the other trigger if necessary.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 21
Past 7 Days: 108
Past 30 Days: 454
All Time: 2,608
