GameSir G4 Pro Battery Replacement
    1. GameSir G4 Pro Battery Replacement, Battery: step 1, image 1 of 2 GameSir G4 Pro Battery Replacement, Battery: step 1, image 2 of 2
      • Remove the dongle from the controller.
      Ask FixBot
    2. GameSir G4 Pro Battery Replacement: step 2, image 1 of 2 GameSir G4 Pro Battery Replacement: step 2, image 2 of 2
      • Use a metal spudger to remove the rubber screw caps on the rear case.
      Ask FixBot
    3. GameSir G4 Pro Battery Replacement: step 3, image 1 of 3 GameSir G4 Pro Battery Replacement: step 3, image 2 of 3 GameSir G4 Pro Battery Replacement: step 3, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the four 9.5 mm screws on the rear case.
      Ask FixBot
    4. GameSir G4 Pro Battery Replacement: step 4, image 1 of 3 GameSir G4 Pro Battery Replacement: step 4, image 2 of 3 GameSir G4 Pro Battery Replacement: step 4, image 3 of 3
      • Use a metal spudger to pry off the two controller grips.
      Ask FixBot
    5. GameSir G4 Pro Battery Replacement: step 5, image 1 of 3 GameSir G4 Pro Battery Replacement: step 5, image 2 of 3 GameSir G4 Pro Battery Replacement: step 5, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the 9.5 mm screws on the top of each handle.
      • Use a Phillips #0 screwdriver to remove the 9.5 mm screws on the bottom of each handle.
      Ask FixBot
    6. GameSir G4 Pro Battery Replacement: step 6, image 1 of 1
      • Optional: Wrap an antistatic wrist strap around your wrist and attach the clamp to a grounded metal surface.
      Ask FixBot
    7. GameSir G4 Pro Battery Replacement: step 7, image 1 of 2 GameSir G4 Pro Battery Replacement: step 7, image 2 of 2
      • Remove the back panel.
      Ask FixBot
    8. GameSir G4 Pro Battery Replacement: step 8, image 1 of 2 GameSir G4 Pro Battery Replacement: step 8, image 2 of 2
      • Use tweezers or your fingernails to walk the white battery connector out of its motherboard socket.
      Ask FixBot
    9. GameSir G4 Pro Battery Replacement: step 9, image 1 of 2 GameSir G4 Pro Battery Replacement: step 9, image 2 of 2
      • Lift and remove the battery.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 103
All Time: 301
