Game Boy Pocket LCD Screen Replacement
    1. Game Boy Pocket LCD Screen Replacement, Remove the external screws: step 1, image 1 of 3 Game Boy Pocket LCD Screen Replacement, Remove the external screws: step 1, image 2 of 3 Game Boy Pocket LCD Screen Replacement, Remove the external screws: step 1, image 3 of 3
      • Place the Game Boy Pocket face-down on a clean, flat surface.
      • Remove batteries from battery compartment.
      • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
      • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
      Ask FixBot
    2. Game Boy Pocket LCD Screen Replacement, Open the device: step 2, image 1 of 3 Game Boy Pocket LCD Screen Replacement, Open the device: step 2, image 2 of 3 Game Boy Pocket LCD Screen Replacement, Open the device: step 2, image 3 of 3
      • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
      • Set the back cover aside. You will need it to reassemble the device.
      Ask FixBot
    3. Game Boy Pocket LCD Screen Replacement, Remove the motherboard screws: step 3, image 1 of 1
      • Use a Phillips #1 screwdriver and turn counterclockwise to remove the three screws on the motherboard.
      Ask FixBot
    4. Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: step 4, image 1 of 3 Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: step 4, image 2 of 3 Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: step 4, image 3 of 3
      • Use a plastic opening tool to dislodge and remove the clip securing the ribbon cable.
      • Make sure you apply pressure on both sides of the clip to loosen it.
      Ask FixBot
    5. Game Boy Pocket LCD Screen Replacement, Dislodge the ribbon cable: step 5, image 1 of 2 Game Boy Pocket LCD Screen Replacement, Dislodge the ribbon cable: step 5, image 2 of 2
      • Use a plastic opening tool to dislodge the ribbon cable.
      • Be gentle to prevent tearing the ribbon.
      Ask FixBot
    6. Game Boy Pocket LCD Screen Replacement, Remove the motherboard: step 6, image 1 of 3 Game Boy Pocket LCD Screen Replacement, Remove the motherboard: step 6, image 2 of 3 Game Boy Pocket LCD Screen Replacement, Remove the motherboard: step 6, image 3 of 3
      • Grab the black piece protruding from the motherboard, and lift up to remove the motherboard.
      • Set the motherboard aside. You will need it to reassemble the device.
      Ask FixBot
    7. Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: step 7, image 1 of 3 Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: step 7, image 2 of 3 Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: step 7, image 3 of 3
      • Use a plastic opening tool to lift the LCD screen away from the front cover.
      • Use your fingers to remove the LCD screen.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
21 other people completed this guide.
Adriana Rahrig
1,688 Reputation
5 Guides authored
USF Tampa, Team 1-1, Leahy Fall 2014 Member of USF Tampa, Team 1-1, Leahy Fall 2014
USFT-LEAHY-F14S1G1
4 Members
60 Guides authored
3 Guide Comments
please can anyone give me a website that sells replacemtn screens for the Gameboy pocket?
help please - Reply Share
There's no website that sells replacement screens the only way to get one is to order another Gameboy off of eBay and take out the screen
Isaac fraser - Reply Share
I get mine from Handheld Legend. They have all the Gameboy parts you could ever want.
Chris Pavlik - Reply Share
Past 24 Hours: 15
Past 7 Days: 110
Past 30 Days: 604
All Time: 36,632
