GPD WIN Silicon Pad Replacement
    1. GPD WIN Silicon Pad Replacement, Remove the screw of the case: step 1, image 1 of 2 GPD WIN Silicon Pad Replacement, Remove the screw of the case: step 1, image 2 of 2
      • Remove the case screws
      Ask FixBot
    2. GPD WIN Silicon Pad Replacement, Remove case: step 2, image 1 of 3 GPD WIN Silicon Pad Replacement, Remove case: step 2, image 2 of 3 GPD WIN Silicon Pad Replacement, Remove case: step 2, image 3 of 3
      • There is a small space beside the keyboard, insert the pick and remove the claw
      • As you open the device, you can see that the flexible cable and the battery cable are connected. Then unplug the connector.
      Ask FixBot
    3. GPD WIN Silicon Pad Replacement, Remove screws on the logic board: step 3, image 1 of 2 GPD WIN Silicon Pad Replacement, Remove screws on the logic board: step 3, image 2 of 2
      • Remove screws on the logic board.
      • Because some black threads are mixed, do not forget to remove
      Ask FixBot
    4. GPD WIN Silicon Pad Replacement, Remove the wifi connector on the logic board: step 4, image 1 of 2 GPD WIN Silicon Pad Replacement, Remove the wifi connector on the logic board: step 4, image 2 of 2
      • Remove Wi-Fi antenna cable and LCD connector
      Ask FixBot
    5. GPD WIN Silicon Pad Replacement, Remove the joystick: step 5, image 1 of 2 GPD WIN Silicon Pad Replacement, Remove the joystick: step 5, image 2 of 2
      • Remove the screws of the joystick and remove the flex cable from the connector.
      • Then, it is ready to pull logic board out of the case.
      Ask FixBot
    6. GPD WIN Silicon Pad Replacement, Replace the silicone pad: step 6, image 1 of 2 GPD WIN Silicon Pad Replacement, Replace the silicone pad: step 6, image 2 of 2
      • You can access the silicone pad by removing the logic board.
      • Replace a sticky silicon pad
      Ask FixBot
To reassemble your device, please follow these steps in reverse order.
2 other people completed this guide.
Special thanks to these translators:
jp en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
noria901
509 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 69
All Time: 3,904
