This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
How to fix mouse wheel clicks on G903
  1. How to fix mouse wheel clicks on G903, How to fix mouse wheel clicks on G903: step 1, image 1 of 1
    • Remove the screw.
    • Pull it apart into two pieces.
    • If you remove the default sole, you can't put it back on, so you need to buy it in advance.
    • Six screws in total.
  2. How to fix mouse wheel clicks on G903: step 2, image 1 of 1
    • Remove the pin by pushing it with a thin stick or screwdriver
    • Lift the wheel off
  3. How to fix mouse wheel clicks on G903: step 3, image 1 of 1
    • Peel off the Kapton tape on the metal dome switch and take out the metal plate inside
    • Remove all of the kapton tape
    • Once it's gone, it's almost impossible to find it, so don't lose it.
  4. How to fix mouse wheel clicks on G903: step 4, image 1 of 1
    • Bend so that the center rises by about 0.2mm
    • What to do after fixing firmly
    • Do not over bend
  5. How to fix mouse wheel clicks on G903: step 5, image 1 of 1
    • Put the metal plate back
    • Affix Kapton tape to fix (if not available, sellotape can be substituted.)
    • Shape Kapton tape (scotch tape) with a cutter, etc.
To reassemble your device, follow these steps in reverse order.
3 other people completed this guide.
Special thanks to these translators:
jp en
85%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Furumatsu Keita
228 Reputation
1 Guide authored
1 Guide Comment
Putting a tiny kink into the metal dome worked perfectly. And I already had a roll of Kapton tape on hand. I never would've realized the little dome was only held on by the tape if not for this guide. Just figured the tape was there to prevent shorting on top or something. That thought made little sense once I saw a bunch of these buttons available and designed without tape but a metal case instead.
Themicles - Reply
Past 24 Hours: 2
Past 7 Days: 46
Past 30 Days: 211
All Time: 4,595
