Fujitsu Lifebook Stylistic Q584 Back Case Replacement
  1. Fujitsu Lifebook Stylistic Q584 Back Case Replacement, Back Case: step 1, image 1 of 1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Back Case Replacement: step 2, image 1 of 1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Back Case Replacement: step 3, image 1 of 1
    • Carefully lift the back case and remove smartcard ribbon from motherboard.
Spencer Bacon
410 Reputation
4 Guides authored
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 19
All Time: 831
