Introduction
The back case is the exterior shell of the device. It needs to be removed in order to access internal components.
Remove the white sticker covering the screws (if applicable).
Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
Insert the plastic opening tool along seam of back case.
Gently slide the plastic opening tool along entire seam popping the clips free.
