Installing Fujifilm Finepix F10 6.3 MP Shutter Button
  1. Installing Fujifilm Finepix F10 6.3 MP Shutter Button, Back Cover: step 1, image 1 of 1
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Installing Fujifilm Finepix F10 6.3 MP Shutter Button: step 2, image 1 of 1
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Installing Fujifilm Finepix F10 6.3 MP Shutter Button: step 3, image 1 of 1
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Installing Fujifilm Finepix F10 6.3 MP Shutter Button: step 4, image 1 of 3 Installing Fujifilm Finepix F10 6.3 MP Shutter Button: step 4, image 2 of 3 Installing Fujifilm Finepix F10 6.3 MP Shutter Button: step 4, image 3 of 3
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Installing Fujifilm Finepix F10 6.3 MP Shutter Button, LCD: step 5, image 1 of 1
    • Remove screws from the casing covering the LCD using the Phillips 00 screwdriver.
    • Remove the fifteen 2.9 mm Phillips #00 screws.
  6. Installing Fujifilm Finepix F10 6.3 MP Shutter Button: step 6, image 1 of 1
    • Slide casing out using the spudger.
  7. Installing Fujifilm Finepix F10 6.3 MP Shutter Button: step 7, image 1 of 2 Installing Fujifilm Finepix F10 6.3 MP Shutter Button: step 7, image 2 of 2
    • Gently remove the LCD display data cable by gripping the end that is connected to the motherboard and pulling out.
  8. Installing Fujifilm Finepix F10 6.3 MP Shutter Button, Shutter Button: step 8, image 1 of 2 Installing Fujifilm Finepix F10 6.3 MP Shutter Button, Shutter Button: step 8, image 2 of 2
    • Pull on the shutter button display data cable on the end connected to the motherboard until it slides out.
  9. Installing Fujifilm Finepix F10 6.3 MP Shutter Button: step 9, image 1 of 2 Installing Fujifilm Finepix F10 6.3 MP Shutter Button: step 9, image 2 of 2
    • While slightly rotating the shutter button and data cable counter-clockwise, pull out until whole component comes out.
    • When inserting the new shutter button and data cable component, be sure it is placed properly into the camera or it will not function correctly.
Sarah Looper
100 Reputation
7 Guides authored
Clemson, Team 13-4, Benson Spring 2013 Member of Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
2 Members
16 Guides authored
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 10
All Time: 1,050
