Fujifilm Finepix F10 6.3 MP Shutter Button Replacement
  1. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement, Back Cover: step 1, image 1 of 1
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: step 2, image 1 of 1
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: step 3, image 1 of 1
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: step 4, image 1 of 3 Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: step 4, image 2 of 3 Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: step 4, image 3 of 3
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement, LCD: step 5, image 1 of 1
    • Remove screws from the casing covering the LCD using the Phillips 00 screwdriver.
    • Remove the fifteen 2.9 mm Phillips #00 screws.
  6. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: step 6, image 1 of 1
    • Slide casing out using the spudger.
  7. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: step 7, image 1 of 2 Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: step 7, image 2 of 2
    • Gently remove the LCD display data cable by gripping the end that is connected to the motherboard and pulling out.
  8. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement, Shutter Button: step 8, image 1 of 2 Fujifilm Finepix F10 6.3 MP Shutter Button Replacement, Shutter Button: step 8, image 2 of 2
    • Pull on the shutter button display data cable on the end connected to the motherboard until it slides out.
  9. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: step 9, image 1 of 2 Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: step 9, image 2 of 2
    • While slightly rotating the shutter button and data cable counter-clockwise, pull out until whole component comes out.
    • When inserting the new shutter button and data cable component, be sure it is placed properly into the camera or it will not function correctly.
Sarah Looper
100 Reputation
7 Guides authored
Clemson, Team 13-4, Benson Spring 2013 Member of Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
2 Members
16 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 14
All Time: 1,046
