Frigidaire Side-by-Side Refrigerator Ice Maker Replacement
  1. Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Unplug your refrigerator: step 1, image 1 of 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Remove the ice bin: step 2, image 1 of 2 Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Remove the ice bin: step 2, image 2 of 2
    • Open the freezer door.
    • Grasp the lower portion of the front of the ice bin.
    • Lift it slightly and pull it out toward the front of the refrigerator.
  3. Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Unfasten the ice maker: step 3, image 1 of 3 Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Unfasten the ice maker: step 3, image 2 of 3 Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Unfasten the ice maker: step 3, image 3 of 3
    • These screws are challenging to reach.
    • Use a 1/4" nut driver to remove the two screws securing the ice maker to the sidewall of the freezer compartment.
  4. Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Reposition the ice maker: step 4, image 1 of 2 Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Reposition the ice maker: step 4, image 2 of 2
    • Rotate the ice maker to the right and lower the front end to access the cable.
  5. Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Disconnect the icemaker: step 5, image 1 of 3 Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Disconnect the icemaker: step 5, image 2 of 3 Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Disconnect the icemaker: step 5, image 3 of 3
    • Locate the ice maker connector near the back of the freezer.
    • Squeeze the release tabs on the connector to release it, and pull it out to disconnect it.
    • You may need to use two hands to do this, one on the rear half and one on the front half of the connector.
    • You can support the ice maker on the ice bin support if you need both hands to disconnect it.
  6. Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Remove the ice maker: step 6, image 1 of 2 Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Remove the ice maker: step 6, image 2 of 2
    • Remove the ice maker from the freezer compartment.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
38,494 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,605 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 62
Past 30 Days: 285
All Time: 3,691
