Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement
  1. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Unplug your refrigerator: step 1, image 1 of 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove the ice bin: step 2, image 1 of 2 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove the ice bin: step 2, image 2 of 2
    • Open the freezer door.
    • Grasp the lower portion of the front of the ice bin.
    • Lift it slightly and pull it out toward the front of the refrigerator.
  3. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Unfasten the ice maker: step 3, image 1 of 3 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Unfasten the ice maker: step 3, image 2 of 3 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Unfasten the ice maker: step 3, image 3 of 3
    • These screws are challenging to reach.
    • Use a 1/4" nut driver to remove the two screws securing the ice maker to the sidewall of the freezer compartment.
  4. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Reposition the ice maker: step 4, image 1 of 2 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Reposition the ice maker: step 4, image 2 of 2
    • Rotate the ice maker to the right and lower the front end to access the cable.
  5. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Disconnect the icemaker: step 5, image 1 of 3 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Disconnect the icemaker: step 5, image 2 of 3 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Disconnect the icemaker: step 5, image 3 of 3
    • Locate the ice maker connector near the back of the freezer.
    • Squeeze the release tabs on the connector to release it, and pull it out to disconnect it.
    • You may need to use two hands to do this, one on the rear half and one on the front half of the connector.
    • You can support the ice maker on the ice bin support if you need both hands to disconnect it.
  6. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove the ice maker: step 6, image 1 of 2 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove the ice maker: step 6, image 2 of 2
    • Remove the ice maker from the freezer compartment.
  7. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove left side freezer drawer rail: step 7, image 1 of 2 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove left side freezer drawer rail: step 7, image 2 of 2
    • Use a 1/4" nut driver to remove the two screws securing the left side freezer drawer rail.
    • Remove the drawer rail
  8. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Unfasten auger motor assembly: step 8, image 1 of 1
    • Use a 1/4" nut driver to remove the two screws securing the auger motor assembly to the support brackets located in the rear of the freezer compartment.
  9. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Reposition auger motor assembly: step 9, image 1 of 3 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Reposition auger motor assembly: step 9, image 2 of 3 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Reposition auger motor assembly: step 9, image 3 of 3
    • Lift the front end rail tie of the auger motor assembly to release it from the support brackets.
    • Lift the entire assembly upward and move it out toward the front of the freezer compartment.
    • Do not try to remove the entire auger motor assembly at this point. It is still connected by electrical cables to the rear of the freezer compartment.
    • Lower the assembly so it will be supported by the front portion of the assembly resting on a shelf located below. Avoid putting tension on the cable.
  10. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Disconnect the auger motor assembly: step 10, image 1 of 2 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Disconnect the auger motor assembly: step 10, image 2 of 2
    • Squeeze the release tab on the auger motor assembly cable and pull the connector out from the socket to disconnect it.
  11. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove the auger motor assembly: step 11, image 1 of 1
    • Remove the auger motor assembly.
    • The assembly is quite unbalanced with a lot of weight to the rear, so hold it near the rear portion.
  12. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove mounting brackets: step 12, image 1 of 2 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove mounting brackets: step 12, image 2 of 2
    • Use a 1/4" nut driver to remove the two screws securing the left-hand auger motor assembly mounting bracket.
    • Repeat the step above for the right-hand bracket.
  13. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Unfasten the upper evaporator cover.: step 13, image 1 of 2 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Unfasten the upper evaporator cover.: step 13, image 2 of 2
    • Use a 1/4" nut driver to remove the five screws securing the upper evaporator panel.
    • Use a 1/4" nut driver to remove the two additional screws securing the upper and lower evaporator panels
  14. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove the upper evaporator cover: step 14, image 1 of 3 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove the upper evaporator cover: step 14, image 2 of 3 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove the upper evaporator cover: step 14, image 3 of 3
    • Use the hole in the upper evaporator cover to lift the upper evaporator cover off.
    • The sheet metal is sharp, and you should consider gloves to protect your hands. Work carefully.
  15. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Unfasten the lower evaporator cover: step 15, image 1 of 1
    • Use a 1/4" nut driver to remove the two remaining screws securing the lower evaporator cover.
  16. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove the lower evaporator cover: step 16, image 1 of 3 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove the lower evaporator cover: step 16, image 2 of 3 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove the lower evaporator cover: step 16, image 3 of 3
    • Lift the lower evaporator cover about 1/2" (13mm) to free it from the rear of the refrigerator.
    • Tilt the top of the lower evaporator cover toward the front of the fridge.
    • Remove the lower evaporator cover.
  17. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Reposition evaporator fan assembly: step 17, image 1 of 2 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Reposition evaporator fan assembly: step 17, image 2 of 2
    • Lift the evaporator fan assembly up from where it is located on the rear of the freezer compartment.
    • Turn the evaporator fan assembly over to the underside to more readily access the electrical connections.
  18. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Disconnect evaporator fan: step 18, image 1 of 3 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Disconnect evaporator fan: step 18, image 2 of 3 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Disconnect evaporator fan: step 18, image 3 of 3
    • Grasp the evaporator fan connector and squeeze the release tabs located on each side of the connector.
    • Separate the connector by pulling it apart. You may need both hands to do this, one on each half of the connector.
  19. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove the evaporator fan assembly: step 19, image 1 of 1
    • Remove the evaporator fan assembly
  20. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove fan blades: step 20, image 1 of 3 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove fan blades: step 20, image 2 of 3 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove fan blades: step 20, image 3 of 3
    • Grasp the hub of the fan blades and pull them off the motor shaft.
  21. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Unhook the fan motor bracket: step 21, image 1 of 3 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Unhook the fan motor bracket: step 21, image 2 of 3 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Unhook the fan motor bracket: step 21, image 3 of 3
    • Press the retaining tab toward the motor shaft to release the fan motor bracket.
    • You can use a spudger or your fingers to press the tab.
    • Unhook the fan motor bracket by pushing it downward once the retaining tab is released.
  22. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove the fan motor bracket: step 22, image 1 of 3 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove the fan motor bracket: step 22, image 2 of 3 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove the fan motor bracket: step 22, image 3 of 3
    • Press the bottom of the bracket inward to release the hook.
    • While pressing inward, pull the hook upward to free the motor bracket.
    • Repeat the last three steps for the other side of the fan motor bracket.
  23. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove motor and motor bracket from evaporator fan assembly: step 23, image 1 of 3 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove motor and motor bracket from evaporator fan assembly: step 23, image 2 of 3 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove motor and motor bracket from evaporator fan assembly: step 23, image 3 of 3
    • Lift motor bracket and motor from evaporator fan assembly.
  24. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove motor from motor bracket: step 24, image 1 of 3 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove motor from motor bracket: step 24, image 2 of 3 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Remove motor from motor bracket: step 24, image 3 of 3
    • Pull the motor bracket upward to separate the motor from the motor bracket.
  25. Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Fan motor is ready for replacement: step 25, image 1 of 2 Frigidaire Side-By-Side Refrigerator Evaporator Fan Replacement, Fan motor is ready for replacement: step 25, image 2 of 2
    • Fan motor can now be replaced.
    • Keep track of the rubber mounting bushings on both faces of the motor as the replacement motor may not come with them.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
38,497 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,623 Guides authored
0 Guide Comments
Past 24 Hours: 19
Past 7 Days: 106
Past 30 Days: 526
All Time: 6,662
