In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Introduction
Go to step 1 ↓Use this guide to replace the run capacitor on your Frigidaire refrigerator. This guide will work for most models that have the run capacitor attached to the motor starting and thermal protection device also known as a control unit or start relay.
The run capacitor allows the compressor to both start and run properly.
If the capacitor is failing, the ability of the refrigerator to cool its interior will be decreased, because the compressor may run poorly. The compressor will not run if the capacitor has failed completely, as it will be unable to start.
This guide was created using a Frigidaire model FFSS2614QS6A side-by-side refrigerator. Other side-by-side units should be similar as will most other Frigidaire refrigerators.
Tools
Unplug your refrigerator before you begin your repair.
Condenser fan motor
Compressor motor and thermal overload device
Water supply valve assembly
Use a 1/4" nut driver to remove the four screws securing the rear cover to the refrigerator.
Lift the rear cover until it is free of the tabs.
If the water supply hose is not used, pass it through the hole in the cover.
Gently pry up the locking tab on the condenser fan connector.
Pull the condenser fan connector off of the start relay.
Use a pair of long nose pliers to grip the retaining clip near the attachment point on the start relay.
Pull the clip toward the compressor so the hook on the clip can be moved through the hole on the start relay.
Move the hook out of the hole to release the clip
Once one side of the retaining clip is released, use your fingers to remove it from the mounting hole on the other side of the start relay.
Remove the clip and set it aside.
Pull the start relay straight off the side of the compressor.
Pull the run capacitor off the start relay.
