Framework Laptop 16" Wi-Fi Card Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 16" Wi-Fi Card Installation, Install the Wi-Fi module: step 1, image 1 of 2 Framework Laptop 16" Wi-Fi Card Installation, Install the Wi-Fi module: step 1, image 2 of 2
      • Hold the Wi-Fi module by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
      • Align the Wi-Fi module's gold contacts and notch with the socket on the Mainboard.
      • Insert the Wi-Fi module into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
      • The Wi-Fi module fits into the socket in one orientation. If it doesn't fit, try flipping the module.
      Ask FixBot
    2. Framework Laptop 16" Wi-Fi Card Installation: step 2, image 1 of 3 Framework Laptop 16" Wi-Fi Card Installation: step 2, image 2 of 3 Framework Laptop 16" Wi-Fi Card Installation: step 2, image 3 of 3
      • Hold the Wi-Fi module down with your finger.
      • Position the white antenna cable connector over the left Wi-Fi module's coaxial socket.
      • If you're unsure which cable goes where, refer to the arrows on the Wi-Fi module for which color cable matches with its connector.
      • Tweezers can help position the connector.
      • Use your finger to press the connector into place. You should feel a faint click, and the cable will stay attached to the socket by itself.
      • These connectors are very delicate! If the connector doesn't feel like it's clicking in place, reposition the connector and try again.
      • Repeat the procedure with the black antenna cable.
      Ask FixBot
    3. Framework Laptop 16" Wi-Fi Card Installation: step 3, image 1 of 2 Framework Laptop 16" Wi-Fi Card Installation: step 3, image 2 of 2
      • Slide the clear plastic cover on the module and align its screw with the screw hole cutout.
      Ask FixBot
    4. Framework Laptop 16" Wi-Fi Card Installation, Tighten the Wi-Fi module screw: step 4, image 1 of 2 Framework Laptop 16" Wi-Fi Card Installation, Tighten the Wi-Fi module screw: step 4, image 2 of 2
      • Use your Framework Screwdriver to tighten the captive T5 Torx screw securing Wi-Fi module.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
250,065 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 65
