Framework Laptop 16" Mid Plate Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 16" Mid Plate Removal, Before you begin: step 1, image 1 of 1
      • Unplug all cables and fully shut down your laptop.
      Ask FixBot
    1. Framework Laptop 16" Mid Plate Removal, Remove the Touchpad Spacers: step 2, image 1 of 3 Framework Laptop 16" Mid Plate Removal, Remove the Touchpad Spacers: step 2, image 2 of 3 Framework Laptop 16" Mid Plate Removal, Remove the Touchpad Spacers: step 2, image 3 of 3
      • Use your fingers to slide the Touchpad Spacer toward the bottom edge of the laptop and unclip it.
      • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
      • Lift the Touchpad Spacer off the laptop and remove it.
      Ask FixBot
    2. Framework Laptop 16" Mid Plate Removal: step 3, image 1 of 3 Framework Laptop 16" Mid Plate Removal: step 3, image 2 of 3 Framework Laptop 16" Mid Plate Removal: step 3, image 3 of 3
      • Repeat the same procedure for the other touchpad spacer.
      Ask FixBot
    1. Framework Laptop 16" Mid Plate Removal, Remove the Touchpad Module: step 4, image 1 of 3 Framework Laptop 16" Mid Plate Removal, Remove the Touchpad Module: step 4, image 2 of 3 Framework Laptop 16" Mid Plate Removal, Remove the Touchpad Module: step 4, image 3 of 3
      • Use your fingers to slide the Touchpad Module toward the bottom edge of the laptop and disconnect it.
      • If you're having trouble, check if the Input Module latches are properly unlocked.
      • Lift the Touchpad Module and remove it.
      Ask FixBot
    1. Framework Laptop 16" Mid Plate Removal, Remove the keyboard: step 5, image 1 of 3 Framework Laptop 16" Mid Plate Removal, Remove the keyboard: step 5, image 2 of 3 Framework Laptop 16" Mid Plate Removal, Remove the keyboard: step 5, image 3 of 3
      • The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
      • Grip the two pull tabs along the bottom of the keyboard and lift until its magnets release.
      • Remove the keyboard.
      Ask FixBot
    1. Framework Laptop 16" Mid Plate Removal, Remove the Input Modules: step 6, image 1 of 3 Framework Laptop 16" Mid Plate Removal, Remove the Input Modules: step 6, image 2 of 3 Framework Laptop 16" Mid Plate Removal, Remove the Input Modules: step 6, image 3 of 3
      • Your Input Module(s) might be different, but the procedure to remove them is the same.
      • Grip the pull tab at the bottom of the Input Module and lift until its magnets release.
      • Remove the Input Module.
      • Repeat for any remaining Input Modules.
      Ask FixBot
    1. Framework Laptop 16" Mid Plate Removal, Disconnect the Mid Plate cable: step 7, image 1 of 2 Framework Laptop 16" Mid Plate Removal, Disconnect the Mid Plate cable: step 7, image 2 of 2
      • Grip the black pull tab on the Mid Plate cable press connector.
      • Lift up to disconnect the Mid Plate cable.
      Ask FixBot
    2. Framework Laptop 16" Mid Plate Removal, Loosen the Mid Plate screws: step 8, image 1 of 2 Framework Laptop 16" Mid Plate Removal, Loosen the Mid Plate screws: step 8, image 2 of 2
      • The Mid Plate screws are ordered from 2–17 (number 1 is the press connector). You don't have to follow the order, but you can use it to help keep track of the screws you've loosened.
      • Use your Framework Screwdriver to loosen the 16 captive T5 Torx screws securing the Mid Plate.
      Ask FixBot
    3. Framework Laptop 16" Mid Plate Removal, Remove the Mid Plate: step 9, image 1 of 3 Framework Laptop 16" Mid Plate Removal, Remove the Mid Plate: step 9, image 2 of 3 Framework Laptop 16" Mid Plate Removal, Remove the Mid Plate: step 9, image 3 of 3
      • Use your fingers to lift the Mid Plate off the laptop and remove it.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
250,047 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 107
