Up to 20% off select tools
Framework Laptop 16" Memory Installation (Mainboard)
View statistics:
Past 24 Hours:
0
Past 7 Days:
0
Past 30 Days:
4
All Time:
97
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
    1. Framework Laptop 16" Memory Installation (Mainboard), Install the memory: step 1, image 1 of 3 Framework Laptop 16" Memory Installation (Mainboard), Install the memory: step 1, image 2 of 3 Framework Laptop 16" Memory Installation (Mainboard), Install the memory: step 1, image 3 of 3
      • Hold the memory module by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
      • Orient the module with its label facing down and align the gold contacts with the left socket labeled DDR5 Channel 0.
      • Insert the contact edge into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
      • Press the edges of the memory module down until the side clips lock it in place.
      Ask FixBot
    2. Framework Laptop 16" Memory Installation (Mainboard): step 2, image 1 of 3 Framework Laptop 16" Memory Installation (Mainboard): step 2, image 2 of 3 Framework Laptop 16" Memory Installation (Mainboard): step 2, image 3 of 3
      • Repeat the previous step for the other socket labeled DDR5 Channel 1, except orient the module so its label is facing upward.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
253,071 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 97
