Introduction
Use this guide to replace the battery in your Framework 16" laptop.
Before starting this repair, we recommend discharging your battery to 25% to help make it easier to dispose as e-waste.
Note: the laptop used in this guide is a generic setup of one US keyboard, one numpad module, and two touchpad spacers. Your setup might vary, but the procedure should remain the same.
Use your fingers to slide the Touchpad Spacer toward the bottom edge of the laptop and unclip it.
Lift the Touchpad Spacer off the laptop and remove it.
Use your fingers to slide the Touchpad Module toward the bottom edge of the laptop and disconnect it.
Lift the Touchpad Module and remove it.
Grip the two pull tabs along the bottom of the keyboard and lift until its magnets release.
Remove the keyboard.
Grip the pull tab at the bottom of the Input Module and lift until its magnets release.
Remove the Input Module.
Repeat for any remaining Input Modules.
Grip the black pull tab on the Mid Plate cable press connector.
Lift up to disconnect the Mid Plate cable.
Use your Framework Screwdriver to loosen the 16 captive T5 Torx screws securing the Mid Plate.
Use your fingers to lift the Mid Plate off the laptop and remove it.
Use your Framework Screwdriver to loosen the three captive T5 Torx screws securing the battery.
Grip the black pull tab at the top of the battery and lift to disconnect the battery connector.
Remove the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
