Introduction
Use this guide to replace the Top Cover in your Framework Laptop 16.
The replacement Top Cover comes with the antennas and webcam cable pre-installed, but you'll need to transfer your display, eDP cable, and webcam.
Use your fingernail to pull out the two Input Module latches and unlock them.
Use your fingers to slide the Touchpad Spacer toward the bottom edge of the laptop and unclip it.
Lift the Touchpad Spacer off the laptop and remove it.
Use your fingers to slide the Touchpad Module toward the bottom edge of the laptop and disconnect it.
Lift the Touchpad Module and remove it.
Grip the two pull tabs along the bottom of the keyboard and lift until its magnets release.
Remove the keyboard.
Grip the pull tab at the bottom of the Input Module and lift until its magnets release.
Remove the Input Module.
Repeat for any remaining Input Modules.
Grip the black pull tab on the Mid Plate cable press connector.
Lift up to disconnect the Mid Plate cable.
Use your Framework Screwdriver to loosen the 16 captive T5 Torx screws securing the Mid Plate.
Use your fingers to lift the Mid Plate off the laptop and remove it.
Lift the interposer door by its black pull tab and let it rest upright.
If you have the Graphics Module, use your Framework Screwdriver to loosen the four captive T5 Torx screws securing the interposer.
If you have the Expansion Bay Shell, use your Framework Screwdriver to loosen the three captive T5 Torx screws securing the interposer.
Use your Framework Screwdriver to loosen the two captive T5 Torx screws securing the module in the Expansion Bay.
Close the interposer door before continuing.
Close your laptop and flip it over.
Slide the Expansion Bay Module out of the laptop and remove it.
Flip your laptop and reopen it.
Use the flat end of your Framework Screwdriver, or a clean fingernail, to lift up the locking tab on the fingerprint reader ZIF connector next to the memory.
Lift the bottom of the ventilation plate and pull it away from the laptop until the magnets release.
Remove the ventilation plate.
Use your Framework Screwdriver to loosen the captive T5 Torx screw securing Wi-Fi module.
Slide the clear plastic cover straight off the module and remove it.
While holding the Wi-Fi module down, insert the flat end of your Framework Screwdriver one of the coaxial connectors, where the cable meets the metal head.
Lift the screwdriver straight up to disconnect the coaxial cable.
Repeat for the other coaxial cable.
Slide your fingernail under the inside edge of either bottom corner of the bezel.
Pull the bezel away from the screen to release the first few magnets.
Lift the bezel around the perimeter of the screen until all of its magnets are released.
Remove the bezel.
Grip the eDP cable connector to the right of the Wi-Fi module slot by its pull tab and lift up to disconnect it.
Repeat for the webcam cable connector next to it.
Lift the eDP, webcam, and antenna cables out of their vertical slot in the Bottom Cover.
While supporting the display with one hand, use your Framework Screwdriver to remove the four 2.4 mm‑long T5 Torx screws securing the display.
Grab the display and pull it straight off the Top Cover to free it from its alignment pegs.
Remove the display.
While supporting the Bottom Cover with one hand, use your Framework Screwdriver to remove the five 2.4 mm‑long screws on each hinge connected to the Top Cover (10 total).
Use the flat end of your Framework Screwdriver, or a clean fingernail, to lift up the locking tab on the webcam ZIF connector.
Use your Framework Screwdriver to remove the two 2.0 mm‑long T5 Torx screws securing the webcam.
Use the magnetic tip of your Framework Screwdriver to pull the two washers off the Top Cover.
Use your fingers to lift the webcam out of the Top Cover and remove it.
Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
Use your fingers to place the washers into their spots on the Top Cover.
Use your Framework Screwdriver to install the two 2.0 mm‑long T5 Torx screws securing the webcam.
Place the Bottom Cover over the Top Cover, making sure the hinges are slotted into their alignment pegs.
While supporting the Bottom Cover with one hand, use your Framework Screwdriver to install the five 2.4 mm‑long screws on each hinge connected to the Top Cover (10 total).
Align the display with its alignment pegs and place it on the Top Cover.
While supporting the display with one hand, use your Framework Screwdriver to install the four 2.4 mm‑long T5 Torx screws securing the display.
Press the bend in the eDP cable onto the Top Cover to re‑adhere it.
Use the flat end of your Framework Screwdriver, or your fingers, to press the webcam cable into its clips at the top right edge of the Bottom Cover.
Press the eDP and webcam cable connectors straight down into their sockets to connect them.
Align the bezel over the perimeter of the display and let the magnets pull the bezel into place.
Hold the Wi-Fi module down with your finger.
Position the white antenna cable connector over the left Wi-Fi module's coaxial socket.
Use your finger to press the connector into place. You should feel a faint click, and the cable will stay attached to the socket by itself.
Repeat the procedure with the black antenna cable.
Slide the clear plastic cover on the module and align its screw with the screw hole cutout.
Use your Framework Screwdriver to tighten the captive T5 Torx screw securing Wi-Fi module.
Lay the ventilation plate along the top edge of the laptop and let its magnets pull into place.
Use your fingers to grip the blue pull tab and slide the fingerprint reader cable straight into its socket.
If you have the Graphics Module, use your Framework Screwdriver to tighten the four captive T5 Torx screws securing the interposer.
If you have the Expansion Bay Shell, use your Framework Screwdriver to tighten the three captive T5 Torx screws securing the interposer.
Close the interposer door.
Place the interposer over its spot between the Mainboard and the module.
Use your Framework Screwdriver to tighten the two captive T5 Torx screws securing the Expansion Bay Module.
Align the Expansion Bay Module with its slot in the laptop.
Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs.
Use your Framework Screwdriver to tighten the 16 captive T5 Torx screws in order (starting with 2) to secure the Mid Plate evenly.
Align the Mid Plate cable press connector over its socket and press down to connect it.
Align the top edge of the Input Module with the top edge of the laptop.
Lay the Input Module on the laptop and let the magnets pull the keyboard into place
Align the top edge of the keyboard with the top edge of the laptop.
Lay the keyboard on the laptop and let the magnets pull the keyboard into place
Place the Touchpad Module flat on its cutout so its clips are properly aligned.
Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
Place the Touchpad Spacer over its spot on the laptop with the bottom edge overhanging slightly.
Slide the Touchpad Spacer towards the top of the laptop to secure it.
Repeat the same procedure for the other Touchpad Spacer.
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
