Framework Laptop 16 Mid Plate Cable Replacement
    1. Framework Laptop 16 Mid Plate Cable Replacement, Before you begin: step 1, image 1 of 1
      • Unplug all cables and fully shut down your laptop.
      Ask FixBot
    1. Framework Laptop 16 Mid Plate Cable Replacement, Unlock the Input Modules: step 2, image 1 of 3 Framework Laptop 16 Mid Plate Cable Replacement, Unlock the Input Modules: step 2, image 2 of 3 Framework Laptop 16 Mid Plate Cable Replacement, Unlock the Input Modules: step 2, image 3 of 3
      • Use your fingernail to pull out the two Input Module latches and unlock them.
      • The latch will show red if it's unlocked.
      Ask FixBot
    2. Framework Laptop 16 Mid Plate Cable Replacement, Remove the Touchpad Spacers: step 3, image 1 of 3 Framework Laptop 16 Mid Plate Cable Replacement, Remove the Touchpad Spacers: step 3, image 2 of 3 Framework Laptop 16 Mid Plate Cable Replacement, Remove the Touchpad Spacers: step 3, image 3 of 3
      • Use your fingers to slide the Touchpad Spacer toward the bottom edge of the laptop and unclip it.
      • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
      • Lift the Touchpad Spacer off the laptop and remove it.
      Ask FixBot
    3. Framework Laptop 16 Mid Plate Cable Replacement: step 4, image 1 of 3 Framework Laptop 16 Mid Plate Cable Replacement: step 4, image 2 of 3 Framework Laptop 16 Mid Plate Cable Replacement: step 4, image 3 of 3
      • Repeat the same procedure for the other touchpad spacer.
      Ask FixBot
    4. Framework Laptop 16 Mid Plate Cable Replacement, Remove the Touchpad Module: step 5, image 1 of 3 Framework Laptop 16 Mid Plate Cable Replacement, Remove the Touchpad Module: step 5, image 2 of 3 Framework Laptop 16 Mid Plate Cable Replacement, Remove the Touchpad Module: step 5, image 3 of 3
      • Use your fingers to slide the Touchpad Module toward the bottom edge of the laptop and disconnect it.
      • If you're having trouble, check if the Input Module latches are properly unlocked.
      • Lift the Touchpad Module and remove it.
      Ask FixBot
    1. Framework Laptop 16 Mid Plate Cable Replacement, Remove the keyboard: step 6, image 1 of 3 Framework Laptop 16 Mid Plate Cable Replacement, Remove the keyboard: step 6, image 2 of 3 Framework Laptop 16 Mid Plate Cable Replacement, Remove the keyboard: step 6, image 3 of 3
      • The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
      • Grip the two pull tabs along the bottom of the keyboard and lift until its magnets release.
      • Remove the keyboard.
      Ask FixBot
    1. Framework Laptop 16 Mid Plate Cable Replacement, Remove the Input Modules: step 7, image 1 of 3 Framework Laptop 16 Mid Plate Cable Replacement, Remove the Input Modules: step 7, image 2 of 3 Framework Laptop 16 Mid Plate Cable Replacement, Remove the Input Modules: step 7, image 3 of 3
      • Your Input Module(s) might be different, but the procedure to remove them is the same.
      • Grip the pull tab at the bottom of the Input Module and lift until its magnets release.
      • Remove the Input Module.
      • Repeat for any remaining Input Modules.
      Ask FixBot
    1. Framework Laptop 16 Mid Plate Cable Replacement, Disconnect the Mid Plate cable: step 8, image 1 of 2 Framework Laptop 16 Mid Plate Cable Replacement, Disconnect the Mid Plate cable: step 8, image 2 of 2
      • Grip the black pull tab on the Mid Plate cable press connector.
      • Lift up to disconnect the Mid Plate cable.
      Ask FixBot
    2. Framework Laptop 16 Mid Plate Cable Replacement, Loosen the Mid Plate screws: step 9, image 1 of 2 Framework Laptop 16 Mid Plate Cable Replacement, Loosen the Mid Plate screws: step 9, image 2 of 2
      • The Mid Plate screws are ordered from 2–17 (number 1 is the press connector). You don't have to follow the order, but you can use it to help keep track of the screws you've loosened.
      • Use your Framework Screwdriver to loosen the 16 captive T5 Torx screws securing the Mid Plate.
      Ask FixBot
    3. Framework Laptop 16 Mid Plate Cable Replacement, Remove the Mid Plate: step 10, image 1 of 3 Framework Laptop 16 Mid Plate Cable Replacement, Remove the Mid Plate: step 10, image 2 of 3 Framework Laptop 16 Mid Plate Cable Replacement, Remove the Mid Plate: step 10, image 3 of 3
      • Use your fingers to lift the Mid Plate off the laptop and remove it.
      Ask FixBot
    1. Framework Laptop 16 Mid Plate Cable Replacement, Separate the Mid Plate Cable adhesive: step 11, image 1 of 2 Framework Laptop 16 Mid Plate Cable Replacement, Separate the Mid Plate Cable adhesive: step 11, image 2 of 2
      • Slide the flat end of the Framework Screwdriver under the Mid Plate Cable, near the ZIF connector, to separate the adhesive.
      Ask FixBot
    2. Framework Laptop 16 Mid Plate Cable Replacement, Disconnect the Mid Plate Cable: step 12, image 1 of 2 Framework Laptop 16 Mid Plate Cable Replacement, Disconnect the Mid Plate Cable: step 12, image 2 of 2
      • Use the flat end of the Framework Screwdriver, or a clean fingernail, to lift up the locking tab on the Mid Plate Cable ZIF connector.
      Ask FixBot
    3. Framework Laptop 16 Mid Plate Cable Replacement: step 13, image 1 of 2 Framework Laptop 16 Mid Plate Cable Replacement: step 13, image 2 of 2
      • Use your fingers to grip the black pull tab and slide the Mid Plate Cable straight out of its socket.
      Ask FixBot
    1. Framework Laptop 16 Mid Plate Cable Replacement, Disassembly complete: step 14, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
      Ask FixBot
    1. Framework Laptop 16 Mid Plate Cable Replacement, Connect the Mid Plate Cable: step 15, image 1 of 2 Framework Laptop 16 Mid Plate Cable Replacement, Connect the Mid Plate Cable: step 15, image 2 of 2
      • Use your fingers to grip the black pull tab and slide the Mid Plate Cable straight into its socket.
      Ask FixBot
    2. Framework Laptop 16 Mid Plate Cable Replacement: step 16, image 1 of 3 Framework Laptop 16 Mid Plate Cable Replacement: step 16, image 2 of 3 Framework Laptop 16 Mid Plate Cable Replacement: step 16, image 3 of 3
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to press down the locking tab on the Mid Plate Cable ZIF connector.
      • Press the cable to the Mid Plate to re-adhere it.
      Ask FixBot
    1. Framework Laptop 16 Mid Plate Cable Replacement, Place the Mid Plate: step 17, image 1 of 3 Framework Laptop 16 Mid Plate Cable Replacement, Place the Mid Plate: step 17, image 2 of 3 Framework Laptop 16 Mid Plate Cable Replacement, Place the Mid Plate: step 17, image 3 of 3
      • Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs.
      Ask FixBot
    2. Framework Laptop 16 Mid Plate Cable Replacement, Tighten the Mid Plate screws: step 18, image 1 of 2 Framework Laptop 16 Mid Plate Cable Replacement, Tighten the Mid Plate screws: step 18, image 2 of 2
      • Use your Framework Screwdriver to tighten the 16 captive T5 Torx screws in order (starting with 2) to secure the Mid Plate evenly.
      Ask FixBot
    3. Framework Laptop 16 Mid Plate Cable Replacement, Connect the Mid Plate cable: step 19, image 1 of 2 Framework Laptop 16 Mid Plate Cable Replacement, Connect the Mid Plate cable: step 19, image 2 of 2
      • Align the Mid Plate cable press connector over its socket and press down to connect it.
      Ask FixBot
    1. Framework Laptop 16 Mid Plate Cable Replacement, Install the Input Modules: step 20, image 1 of 3 Framework Laptop 16 Mid Plate Cable Replacement, Install the Input Modules: step 20, image 2 of 3 Framework Laptop 16 Mid Plate Cable Replacement, Install the Input Modules: step 20, image 3 of 3
      • Align the top edge of the Input Module with the top edge of the laptop.
      • Lay the Input Module on the laptop and let the magnets pull the keyboard into place
      • Make sure the Input Module is seated properly on its alignment pegs and sits flush with the edges of the laptop.
      Ask FixBot
    1. Framework Laptop 16 Mid Plate Cable Replacement, Install the keyboard: step 21, image 1 of 3 Framework Laptop 16 Mid Plate Cable Replacement, Install the keyboard: step 21, image 2 of 3 Framework Laptop 16 Mid Plate Cable Replacement, Install the keyboard: step 21, image 3 of 3
      • Align the top edge of the keyboard with the top edge of the laptop.
      • Lay the keyboard on the laptop and let the magnets pull the keyboard into place
      • Make sure the keyboard is seated properly on its alignment pegs and sits flush with the edges of the laptop.
      Ask FixBot
    1. Framework Laptop 16 Mid Plate Cable Replacement, Install the Touchpad Module: step 22, image 1 of 2 Framework Laptop 16 Mid Plate Cable Replacement, Install the Touchpad Module: step 22, image 2 of 2
      • Place the Touchpad Module flat on its cutout so its clips are properly aligned.
      • Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
      Ask FixBot
    2. Framework Laptop 16 Mid Plate Cable Replacement, Install the Touchpad Spacers: step 23, image 1 of 3 Framework Laptop 16 Mid Plate Cable Replacement, Install the Touchpad Spacers: step 23, image 2 of 3 Framework Laptop 16 Mid Plate Cable Replacement, Install the Touchpad Spacers: step 23, image 3 of 3
      • Place the Touchpad Spacer over its spot on the laptop with the bottom edge overhanging slightly.
      • Slide the Touchpad Spacer towards the top of the laptop to secure it.
      • Repeat the same procedure for the other Touchpad Spacer.
      Ask FixBot
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
Alex Diaz-Kokaisl
249,970 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 60
All Time: 268
