Shop the Holiday Gift Guide
Framework Laptop 16 Memory Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
24
Past 30 Days:
89
All Time:
426
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Follow this guide to remove and replace the memory (aka RAM) in your Framework Laptop 16.
Your Framework Laptop has two DDR5 SO-DIMM sockets that supports up to 32 GB each of DDR5-5600 memory. If you install memory faster than the supported speed, the laptop will work properly, but not use the full memory speed.
For a list of validated memory modules, check out this link.
    1. Framework Laptop 16 Memory Replacement, Before you begin: step 1, image 1 of 1
      • Unplug all cables and fully shut down your laptop.
      Ask FixBot
    1. Framework Laptop 16 Memory Replacement, Remove the Touchpad Spacers: step 2, image 1 of 3 Framework Laptop 16 Memory Replacement, Remove the Touchpad Spacers: step 2, image 2 of 3 Framework Laptop 16 Memory Replacement, Remove the Touchpad Spacers: step 2, image 3 of 3
      • Use your fingers to slide the Touchpad Spacer toward the bottom edge of the laptop and unclip it.
      • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
      • Lift the Touchpad Spacer off the laptop and remove it.
      Ask FixBot
    2. Framework Laptop 16 Memory Replacement: step 3, image 1 of 3 Framework Laptop 16 Memory Replacement: step 3, image 2 of 3 Framework Laptop 16 Memory Replacement: step 3, image 3 of 3
      • Repeat the same procedure for the other touchpad spacer.
      Ask FixBot
    1. Framework Laptop 16 Memory Replacement, Remove the Touchpad Module: step 4, image 1 of 3 Framework Laptop 16 Memory Replacement, Remove the Touchpad Module: step 4, image 2 of 3 Framework Laptop 16 Memory Replacement, Remove the Touchpad Module: step 4, image 3 of 3
      • Use your fingers to slide the Touchpad Module toward the bottom edge of the laptop and disconnect it.
      • If you're having trouble, check if the Input Module latches are properly unlocked.
      • Lift the Touchpad Module and remove it.
      Ask FixBot
    1. Framework Laptop 16 Memory Replacement, Remove the keyboard: step 5, image 1 of 3 Framework Laptop 16 Memory Replacement, Remove the keyboard: step 5, image 2 of 3 Framework Laptop 16 Memory Replacement, Remove the keyboard: step 5, image 3 of 3
      • The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
      • Grip the two pull tabs along the bottom of the keyboard and lift until its magnets release.
      • Remove the keyboard.
      Ask FixBot
    1. Framework Laptop 16 Memory Replacement, Remove the Input Modules: step 6, image 1 of 3 Framework Laptop 16 Memory Replacement, Remove the Input Modules: step 6, image 2 of 3 Framework Laptop 16 Memory Replacement, Remove the Input Modules: step 6, image 3 of 3
      • Your Input Module(s) might be different, but the procedure to remove them is the same.
      • Grip the pull tab at the bottom of the Input Module and lift until its magnets release.
      • Remove the Input Module.
      • Repeat for any remaining Input Modules.
      Ask FixBot
    1. Framework Laptop 16 Memory Replacement, Disconnect the Mid Plate cable: step 7, image 1 of 2 Framework Laptop 16 Memory Replacement, Disconnect the Mid Plate cable: step 7, image 2 of 2
      • Grip the black pull tab on the Mid Plate cable press connector.
      • Lift up to disconnect the Mid Plate cable.
      Ask FixBot
    2. Framework Laptop 16 Memory Replacement, Loosen the Mid Plate screws: step 8, image 1 of 2 Framework Laptop 16 Memory Replacement, Loosen the Mid Plate screws: step 8, image 2 of 2
      • The Mid Plate screws are ordered from 2–17 (number 1 is the press connector). You don't have to follow the order, but you can use it to help keep track of the screws you've loosened.
      • Use your Framework Screwdriver to loosen the 16 captive T5 Torx screws securing the Mid Plate.
      Ask FixBot
    3. Framework Laptop 16 Memory Replacement, Remove the Mid Plate: step 9, image 1 of 3 Framework Laptop 16 Memory Replacement, Remove the Mid Plate: step 9, image 2 of 3 Framework Laptop 16 Memory Replacement, Remove the Mid Plate: step 9, image 3 of 3
      • Use your fingers to lift the Mid Plate off the laptop and remove it.
      Ask FixBot
    1. Framework Laptop 16 Memory Replacement, Remove the memory: step 10, image 1 of 3 Framework Laptop 16 Memory Replacement, Remove the memory: step 10, image 2 of 3 Framework Laptop 16 Memory Replacement, Remove the memory: step 10, image 3 of 3
      • Push the two metal arms on each side of the module outward until they disengage and the stick pops up at a shallow angle.
      • Repeat for the other module.
      Ask FixBot
    2. Framework Laptop 16 Memory Replacement: step 11, image 1 of 3 Framework Laptop 16 Memory Replacement: step 11, image 2 of 3 Framework Laptop 16 Memory Replacement: step 11, image 3 of 3
      • Slide the memory module out of its socket and remove it.
      Ask FixBot
    1. Framework Laptop 16 Memory Replacement, Disassembly complete: step 12, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
      Ask FixBot
    1. Framework Laptop 16 Memory Replacement, Install the memory: step 13, image 1 of 3 Framework Laptop 16 Memory Replacement, Install the memory: step 13, image 2 of 3 Framework Laptop 16 Memory Replacement, Install the memory: step 13, image 3 of 3
      • Hold the memory module by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
      • Orient the module with its label facing down and align the gold contacts with the left socket labeled DDR5 Channel 0.
      • Insert the contact edge into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
      • Press the edges of the module down until the side clips lock it in place.
      Ask FixBot
    2. Framework Laptop 16 Memory Replacement: step 14, image 1 of 3 Framework Laptop 16 Memory Replacement: step 14, image 2 of 3 Framework Laptop 16 Memory Replacement: step 14, image 3 of 3
      • Repeat the previous step for the other socket labeled DDR5 Channel 1, except orient the module so its label is facing upward.
      Ask FixBot
    1. Framework Laptop 16 Memory Replacement, Place the Mid Plate: step 15, image 1 of 3 Framework Laptop 16 Memory Replacement, Place the Mid Plate: step 15, image 2 of 3 Framework Laptop 16 Memory Replacement, Place the Mid Plate: step 15, image 3 of 3
      • Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs.
      Ask FixBot
    2. Framework Laptop 16 Memory Replacement, Tighten the Mid Plate screws: step 16, image 1 of 2 Framework Laptop 16 Memory Replacement, Tighten the Mid Plate screws: step 16, image 2 of 2
      • Use your Framework Screwdriver to tighten the 16 captive T5 Torx screws in order (starting with 2) to secure the Mid Plate evenly.
      Ask FixBot
    3. Framework Laptop 16 Memory Replacement, Connect the Mid Plate cable: step 17, image 1 of 2 Framework Laptop 16 Memory Replacement, Connect the Mid Plate cable: step 17, image 2 of 2
      • Align the Mid Plate cable press connector over its socket and press down to connect it.
      Ask FixBot
    1. Framework Laptop 16 Memory Replacement, Install the Input Modules: step 18, image 1 of 3 Framework Laptop 16 Memory Replacement, Install the Input Modules: step 18, image 2 of 3 Framework Laptop 16 Memory Replacement, Install the Input Modules: step 18, image 3 of 3
      • Align the top edge of the Input Module with the top edge of the laptop.
      • Lay the Input Module on the laptop and let the magnets pull the keyboard into place
      • Make sure the Input Module is seated properly on its alignment pegs and sits flush with the edges of the laptop.
      Ask FixBot
    1. Framework Laptop 16 Memory Replacement, Install the keyboard: step 19, image 1 of 3 Framework Laptop 16 Memory Replacement, Install the keyboard: step 19, image 2 of 3 Framework Laptop 16 Memory Replacement, Install the keyboard: step 19, image 3 of 3
      • Align the top edge of the keyboard with the top edge of the laptop.
      • Lay the keyboard on the laptop and let the magnets pull the keyboard into place
      • Make sure the keyboard is seated properly on its alignment pegs and sits flush with the edges of the laptop.
      Ask FixBot
    1. Framework Laptop 16 Memory Replacement, Install the Touchpad Module: step 20, image 1 of 2 Framework Laptop 16 Memory Replacement, Install the Touchpad Module: step 20, image 2 of 2
      • Place the Touchpad Module flat on its cutout so its clips are properly aligned.
      • Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
      Ask FixBot
    1. Framework Laptop 16 Memory Replacement, Install the Touchpad Spacers: step 21, image 1 of 3 Framework Laptop 16 Memory Replacement, Install the Touchpad Spacers: step 21, image 2 of 3 Framework Laptop 16 Memory Replacement, Install the Touchpad Spacers: step 21, image 3 of 3
      • Place the Touchpad Spacer over its spot on the laptop with the bottom edge overhanging slightly.
      • Slide the Touchpad Spacer towards the top of the laptop to secure it.
      • Repeat the same procedure for the other Touchpad Spacer.
      Ask FixBot
    2. Framework Laptop 16 Memory Replacement, Lock the Input Modules: step 22, image 1 of 3 Framework Laptop 16 Memory Replacement, Lock the Input Modules: step 22, image 2 of 3 Framework Laptop 16 Memory Replacement, Lock the Input Modules: step 22, image 3 of 3
      • Push the Input Module latches back into place to lock them.
      Ask FixBot
You finished fixing your Framework Laptop!
After installing new memory, the laptop will take longer to start up for the first time, and the screen will turn on slower. This is normal—the system is performing memory training.
If you need help, contact Framework support.
Alex Diaz-Kokaisl
252,429 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 24
Past 30 Days: 89
All Time: 426
