OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓Use this guide to remove and replace the Input Module Connector Board in your Framework Laptop 16.
Use your fingernail to pull out the two Input Module latches and unlock them.
Use your fingers to slide the Touchpad Spacer toward the bottom edge of the laptop and unclip it.
Lift the Touchpad Spacer off the laptop and remove it.
Use your fingers to slide the Touchpad Module toward the bottom edge of the laptop and disconnect it.
Lift the Touchpad Module and remove it.
Grip the two pull tabs along the bottom of the keyboard and lift until its magnets release.
Remove the keyboard.
Grip the black pull tab on the Mid Plate cable press connector.
Lift up to disconnect the Mid Plate cable.
Use your Framework Screwdriver to loosen the 16 captive T5 Torx screws securing the Mid Plate.
Use your fingers to lift the Mid Plate off the laptop and remove it.
Use your Framework Screwdriver to remove the fifteen 1.4 mm‑long Phillips screws securing the Input Module Connector Board.
Lift the Input Module Connector Board off the Mid Plate and remove it.
Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
Place the Input Module Connector Board on the Mid Plate, making sure the connector is aligned with the hole in the Mid Plate.
Use your Framework Screwdriver to install the fifteen 1.4 mm‑long screws securing the Input Module Connector Board.
Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs.
Use your Framework Screwdriver to tighten the 16 captive T5 Torx screws in order (starting with 2) to secure the Mid Plate evenly.
Align the Mid Plate cable press connector over its socket and press down to connect it.
Align the top edge of the Input Module with the top edge of the laptop.
Lay the Input Module on the laptop and let the magnets pull the keyboard into place
Repeat for any remaining Input Modules.
Align the top edge of the keyboard with the top edge of the laptop.
Lay the keyboard on the laptop and let the magnets pull the keyboard into place
Place the Touchpad Module flat on its cutout so its clips are properly aligned.
Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
Place the Touchpad Spacer over its spot on the laptop with the bottom edge overhanging slightly.
Slide the Touchpad Spacer towards the top of the laptop to secure it.
Repeat the same procedure for the other Touchpad Spacer.
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
