Up to 20% off select tools
Framework Laptop 16 Graphics Module Fan Replacement
View statistics:
Past 24 Hours:
6
Past 7 Days:
31
Past 30 Days:
125
All Time:
861
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Easy
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Use this guide to remove and replace one or both of the Graphics Module Fans in your Framework Laptop 16.
The guide shows replacing the right Graphics Module Fan, but the procedure is identical to replace the left fan.
    1. Framework Laptop 16 Graphics Module Fan Replacement, Before you begin: step 1, image 1 of 1
      • Unplug all cables and fully shut down your laptop.
      Ask FixBot
    1. Framework Laptop 16 Graphics Module Fan Replacement, Unlock the Input Modules: step 2, image 1 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Unlock the Input Modules: step 2, image 2 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Unlock the Input Modules: step 2, image 3 of 3
      • Use your fingernail to pull out the two Input Module latches and unlock them.
      • The latch will show red if it's unlocked.
      Ask FixBot
    2. Framework Laptop 16 Graphics Module Fan Replacement, Remove the Touchpad Spacers: step 3, image 1 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the Touchpad Spacers: step 3, image 2 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the Touchpad Spacers: step 3, image 3 of 3
      • Use your fingers to slide the Touchpad Spacer toward the bottom edge of the laptop and unclip it.
      • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
      • Lift the Touchpad Spacer off the laptop and remove it.
      Ask FixBot
    3. Framework Laptop 16 Graphics Module Fan Replacement: step 4, image 1 of 3 Framework Laptop 16 Graphics Module Fan Replacement: step 4, image 2 of 3 Framework Laptop 16 Graphics Module Fan Replacement: step 4, image 3 of 3
      • Repeat the same procedure for the other touchpad spacer.
      Ask FixBot
    4. Framework Laptop 16 Graphics Module Fan Replacement, Remove the Touchpad Module: step 5, image 1 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the Touchpad Module: step 5, image 2 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the Touchpad Module: step 5, image 3 of 3
      • Use your fingers to slide the Touchpad Module toward the bottom edge of the laptop and disconnect it.
      • If you're having trouble, check if the Input Module latches are properly unlocked.
      • Lift the Touchpad Module and remove it.
      Ask FixBot
    1. Framework Laptop 16 Graphics Module Fan Replacement, Remove the keyboard: step 6, image 1 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the keyboard: step 6, image 2 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the keyboard: step 6, image 3 of 3
      • The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
      • Grip the two pull tabs along the bottom of the keyboard and lift until its magnets release.
      • Remove the keyboard.
      Ask FixBot
    1. Framework Laptop 16 Graphics Module Fan Replacement, Remove the Input Modules: step 7, image 1 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the Input Modules: step 7, image 2 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the Input Modules: step 7, image 3 of 3
      • Your Input Module(s) might be different, but the procedure to remove them is the same.
      • Grip the pull tab at the bottom of the Input Module and lift until its magnets release.
      • Remove the Input Module.
      • Repeat for any remaining Input Modules.
      Ask FixBot
    1. Framework Laptop 16 Graphics Module Fan Replacement, Lift the interposer door: step 8, image 1 of 2 Framework Laptop 16 Graphics Module Fan Replacement, Lift the interposer door: step 8, image 2 of 2
      • Lift the interposer door by its black pull tab and let it rest upright.
      Ask FixBot
    2. Framework Laptop 16 Graphics Module Fan Replacement, Loosen the interposer screws: step 9, image 1 of 1
      • Use your Framework Screwdriver to loosen the four captive T5 Torx screws securing the interposer.
      Ask FixBot
    3. Framework Laptop 16 Graphics Module Fan Replacement, Remove the interposer: step 10, image 1 of 2 Framework Laptop 16 Graphics Module Fan Replacement, Remove the interposer: step 10, image 2 of 2
      • Lift the interposer by its pull tab and remove it.
      Ask FixBot
    4. Framework Laptop 16 Graphics Module Fan Replacement, Loosen the Graphics Module screws: step 11, image 1 of 2 Framework Laptop 16 Graphics Module Fan Replacement, Loosen the Graphics Module screws: step 11, image 2 of 2
      • Use your Framework Screwdriver to loosen the two captive T5 Torx screws securing the Graphics Module.
      • Close the interposer door before continuing.
      Ask FixBot
    5. Framework Laptop 16 Graphics Module Fan Replacement, Remove the Graphics Module: step 12, image 1 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the Graphics Module: step 12, image 2 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the Graphics Module: step 12, image 3 of 3
      • Close your laptop and flip it over.
      • Slide the Graphics Module out of the laptop and remove it.
      • The module should slide out easily. If you feel any resistance, check that the screws holding it in place are fully loosened.
      Ask FixBot
    1. Framework Laptop 16 Graphics Module Fan Replacement, Remove the Graphics Module cover screws: step 13, image 1 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the Graphics Module cover screws: step 13, image 2 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the Graphics Module cover screws: step 13, image 3 of 3
      • Use your Framework Screwdriver to remove the four 3.6 mm‑long T5 Torx screws securing the Graphics Module cover:
      • Two screws on the flat surface of the module, next to the fans.
      • Two screws on the thin edge of the module, near the ends. You'll need to flip the module on its back edge to access them.
      Ask FixBot
    2. Framework Laptop 16 Graphics Module Fan Replacement, Remove the Graphics Module cover: step 14, image 1 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the Graphics Module cover: step 14, image 2 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the Graphics Module cover: step 14, image 3 of 3
      • Use your fingers to lift the cover off the Graphics Module and remove it.
      Ask FixBot
    3. Framework Laptop 16 Graphics Module Fan Replacement, Disconnect the fan: step 15, image 1 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Disconnect the fan: step 15, image 2 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Disconnect the fan: step 15, image 3 of 3
      • Use the flat end of a spudger, or a clean fingernail, to lift up and release the locking tab on the fan ZIF connector.
      • Use your fingers to grip the brown pull tab and slide the fan cable straight out of its socket.
      Ask FixBot
    4. Framework Laptop 16 Graphics Module Fan Replacement: step 16, image 1 of 2 Framework Laptop 16 Graphics Module Fan Replacement: step 16, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers, or your fingers, to grip the brown pull tab and slide the fan cable straight out of its socket.
      Ask FixBot
    5. Framework Laptop 16 Graphics Module Fan Replacement, Loosen the fan screws: step 17, image 1 of 2 Framework Laptop 16 Graphics Module Fan Replacement, Loosen the fan screws: step 17, image 2 of 2
      • Use a T5 Torx screwdriver to loosen the four captive screws securing the fan.
      Ask FixBot
    6. Framework Laptop 16 Graphics Module Fan Replacement, Remove the fan: step 18, image 1 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the fan: step 18, image 2 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the fan: step 18, image 3 of 3
      • Use one hand to press the fan cable flat to the module.
      • Use your other hand to pull the fan out of its housing, making sure to thread the cable though its slot.
      • Remove the fan.
      Ask FixBot
    1. Framework Laptop 16 Graphics Module Fan Replacement, Disassembly complete: step 19, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
      Ask FixBot
    1. Framework Laptop 16 Graphics Module Fan Replacement, Install the Graphics Module cover screws: step 20, image 1 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Install the Graphics Module cover screws: step 20, image 2 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Install the Graphics Module cover screws: step 20, image 3 of 3
      • Use your Framework Screwdriver to install the four 3.6 mm‑long T5 Torx screws securing the Graphics Module cover:
      Ask FixBot
    2. Framework Laptop 16 Graphics Module Fan Replacement, Place the Graphics Module cover: step 21, image 1 of 2 Framework Laptop 16 Graphics Module Fan Replacement, Place the Graphics Module cover: step 21, image 2 of 2
      • Place the cover over its slot on the Graphics Module.
      Ask FixBot
    3. Framework Laptop 16 Graphics Module Fan Replacement, Disconnect the fan: step 22, image 1 of 2 Framework Laptop 16 Graphics Module Fan Replacement, Disconnect the fan: step 22, image 2 of 2
      Ask FixBot
    4. Framework Laptop 16 Graphics Module Fan Replacement, Connect the fan: step 23, image 1 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Connect the fan: step 23, image 2 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Connect the fan: step 23, image 3 of 3
      • Use your fingers to grip the brown pull tab and slide the fan cable straight into its socket.
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to press down the locking tab on the fan ZIF connector.
      Ask FixBot
    5. Framework Laptop 16 Graphics Module Fan Replacement, Install the fan screws: step 24, image 1 of 2 Framework Laptop 16 Graphics Module Fan Replacement, Install the fan screws: step 24, image 2 of 2
      • Use a T5 Torx screwdriver to tighten the four captive screws securing the fan.
      Ask FixBot
    6. Framework Laptop 16 Graphics Module Fan Replacement, Place the fan: step 25, image 1 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Place the fan: step 25, image 2 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Place the fan: step 25, image 3 of 3
      • Place the fan onto the Expansion Bay Shell, making sure to thread the cable through its slot.
      Ask FixBot
    1. Framework Laptop 16 Graphics Module Fan Replacement, Insert the Graphics Module: step 26, image 1 of 2 Framework Laptop 16 Graphics Module Fan Replacement, Insert the Graphics Module: step 26, image 2 of 2
      Ask FixBot
    2. Framework Laptop 16 Graphics Module Fan Replacement: step 27, image 1 of 2 Framework Laptop 16 Graphics Module Fan Replacement: step 27, image 2 of 2
      • When installing the module, keep it level to the laptop so it doesn't buckle on the rails.
      • There should be no gaps between the laptop and the module when it's installed correctly.
      Ask FixBot
    3. Framework Laptop 16 Graphics Module Fan Replacement: step 28, image 1 of 3 Framework Laptop 16 Graphics Module Fan Replacement: step 28, image 2 of 3 Framework Laptop 16 Graphics Module Fan Replacement: step 28, image 3 of 3
      • While keeping the module level with the laptop, slide it into its slot.
      • The module should slide in easily. If you feel any resistance, pull the module out and realign it.
      • You should hear an audible "click" when the module's clips snap into place.
      Ask FixBot
    4. Framework Laptop 16 Graphics Module Fan Replacement, Lift the interposer door: step 29, image 1 of 2 Framework Laptop 16 Graphics Module Fan Replacement, Lift the interposer door: step 29, image 2 of 2
      • Flip over the laptop and open it.
      Ask FixBot
    5. Framework Laptop 16 Graphics Module Fan Replacement, Tighten the Graphics Module screws: step 30, image 1 of 2 Framework Laptop 16 Graphics Module Fan Replacement, Tighten the Graphics Module screws: step 30, image 2 of 2
      • Use your Framework Screwdriver to tighten the two captive T5 Torx screws securing the Graphics Module.
      Ask FixBot
    6. Framework Laptop 16 Graphics Module Fan Replacement, Place the interposer: step 31, image 1 of 2 Framework Laptop 16 Graphics Module Fan Replacement, Place the interposer: step 31, image 2 of 2
      • Place the interposer over its spot between the Mainboard and the Graphics Module.
      Ask FixBot
    7. Framework Laptop 16 Graphics Module Fan Replacement, Tighten the interposer screws: step 32, image 1 of 2 Framework Laptop 16 Graphics Module Fan Replacement, Tighten the interposer screws: step 32, image 2 of 2
      • Use your Framework Screwdriver to tighten the four captive T5 Torx screws securing the interposer.
      • Close the interposer door.
      Ask FixBot
    1. Framework Laptop 16 Graphics Module Fan Replacement, Remove the numpad: step 33, image 1 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the numpad: step 33, image 2 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the numpad: step 33, image 3 of 3
      • The numpad is held in place with strong magnets. Apply gradually increasing force to avoid having the numpad violently eject.
      • Grip the pull tab at the bottom of the numpad.
      • Lift the pull tab until the numpad magnets release.
      • Remove the numpad.
      • During reassembly, make sure the numpad is seated properly on its alignment pegs and sits flush with the edges of the laptop.
      Ask FixBot
    1. Framework Laptop 16 Graphics Module Fan Replacement, Install the keyboard: step 34, image 1 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Install the keyboard: step 34, image 2 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Install the keyboard: step 34, image 3 of 3
      • Align the top edge of the keyboard with the top edge of the laptop.
      • Lay the keyboard on the laptop and let the magnets pull the keyboard into place
      • Make sure the keyboard is seated properly on its alignment pegs and sits flush with the edges of the laptop.
      Ask FixBot
    1. Framework Laptop 16 Graphics Module Fan Replacement, Install the Touchpad Module: step 35, image 1 of 2 Framework Laptop 16 Graphics Module Fan Replacement, Install the Touchpad Module: step 35, image 2 of 2
      • Place the Touchpad Module flat on its cutout so its clips are properly aligned.
      • Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
      Ask FixBot
    2. Framework Laptop 16 Graphics Module Fan Replacement, Install the Touchpad Spacers: step 36, image 1 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Install the Touchpad Spacers: step 36, image 2 of 3 Framework Laptop 16 Graphics Module Fan Replacement, Install the Touchpad Spacers: step 36, image 3 of 3
      • Place the Touchpad Spacer over its spot on the laptop with the bottom edge overhanging slightly.
      • Slide the Touchpad Spacer towards the top of the laptop to secure it.
      • Repeat the same procedure for the other Touchpad Spacer.
      Ask FixBot
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
Alex Diaz-Kokaisl
253,252 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 31
Past 30 Days: 125
All Time: 861
