Shop the Holiday Gift Guide
Framework Laptop 16 Display Replacement
View statistics:
Past 24 Hours:
10
Past 7 Days:
29
Past 30 Days:
107
All Time:
503
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Use this guide to remove and replace the display in your Framework Laptop 16.
    1. Framework Laptop 16 Display Replacement, Before you begin: step 1, image 1 of 1
      • Unplug all cables and fully shut down your laptop.
      Ask FixBot
    1. Framework Laptop 16 Display Replacement, Create a gap: step 2, image 1 of 3 Framework Laptop 16 Display Replacement, Create a gap: step 2, image 2 of 3 Framework Laptop 16 Display Replacement, Create a gap: step 2, image 3 of 3
      • The bezel is secured with magnets.
      • Slide your fingernail under the inside edge of either bottom corner of the bezel.
      • Pull the bezel away from the screen to release the first few magnets.
      Ask FixBot
    2. Framework Laptop 16 Display Replacement, Remove the bezel: step 3, image 1 of 3 Framework Laptop 16 Display Replacement, Remove the bezel: step 3, image 2 of 3 Framework Laptop 16 Display Replacement, Remove the bezel: step 3, image 3 of 3
      • Lift the bezel around the perimeter of the screen until all of its magnets are released.
      • Remove the bezel.
      Ask FixBot
    1. Framework Laptop 16 Display Replacement, Remove the display screws: step 4, image 1 of 3 Framework Laptop 16 Display Replacement, Remove the display screws: step 4, image 2 of 3 Framework Laptop 16 Display Replacement, Remove the display screws: step 4, image 3 of 3
      • While supporting the display with one hand, use your Framework Screwdriver to remove the four 2.4 mm‑long T5 Torx screws securing the display.
      Ask FixBot
    2. Framework Laptop 16 Display Replacement, Disconnect the display: step 5, image 1 of 3 Framework Laptop 16 Display Replacement, Disconnect the display: step 5, image 2 of 3 Framework Laptop 16 Display Replacement, Disconnect the display: step 5, image 3 of 3
      • Grab the display and pull it straight off the Top Cover to free it from its alignment pegs.
      • Don't pull the display too far from the Top Cover, as it's still attached by a cable.
      • Flip the front of the display down and rest it on the keyboard.
      Ask FixBot
    3. Framework Laptop 16 Display Replacement, Disconnect the display: step 6, image 1 of 2 Framework Laptop 16 Display Replacement, Disconnect the display: step 6, image 2 of 2
      • Use your fingers to flip up the plastic tab and access the connector underneath.
      Ask FixBot
    4. Framework Laptop 16 Display Replacement: step 7, image 1 of 2 Framework Laptop 16 Display Replacement: step 7, image 2 of 2
      • Use the flat end of your Framework Screwdriver to lift up the metal locking tab over the eDP cable connector.
      Ask FixBot
    5. Framework Laptop 16 Display Replacement: step 8, image 1 of 2 Framework Laptop 16 Display Replacement: step 8, image 2 of 2
      • Grip the eDP cable where it meets the connector head.
      • Slide the connector straight out of its socket to disconnect it.
      Ask FixBot
    1. Framework Laptop 16 Display Replacement, Disassembly complete: step 9, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
      Ask FixBot
    1. Framework Laptop 16 Display Replacement, Connect the display: step 10, image 1 of 2 Framework Laptop 16 Display Replacement, Connect the display: step 10, image 2 of 2
      • Slide the eDP cable connector straight into its socket.
      Ask FixBot
    2. Framework Laptop 16 Display Replacement: step 11, image 1 of 3 Framework Laptop 16 Display Replacement: step 11, image 2 of 3 Framework Laptop 16 Display Replacement: step 11, image 3 of 3
      • Push the metal locking tab down over the eDP cable connector until it snaps into place.
      Ask FixBot
    3. Framework Laptop 16 Display Replacement, Install the display screws: step 12, image 1 of 3 Framework Laptop 16 Display Replacement, Install the display screws: step 12, image 2 of 3 Framework Laptop 16 Display Replacement, Install the display screws: step 12, image 3 of 3
      • While supporting the display with one hand, use your Framework Screwdriver to install the four 2.4 mm‑long T5 Torx screws securing the display.
      Ask FixBot
    4. Framework Laptop 16 Display Replacement, Place the display: step 13, image 1 of 3 Framework Laptop 16 Display Replacement, Place the display: step 13, image 2 of 3 Framework Laptop 16 Display Replacement, Place the display: step 13, image 3 of 3
      • Align the display with its alignment pegs and place it on the Top Cover.
      Ask FixBot
    1. Framework Laptop 16 Display Replacement, Install the bezel: step 14, image 1 of 3 Framework Laptop 16 Display Replacement, Install the bezel: step 14, image 2 of 3 Framework Laptop 16 Display Replacement, Install the bezel: step 14, image 3 of 3
      • Align the bezel over the perimeter of the display and let the magnets pull the bezel into place.
      • The bezel should "snap" into place. If it doesn't, realign it and make sure it sits flush with the display.
      Ask FixBot
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
Alex Diaz-Kokaisl
252,806 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 29
Past 30 Days: 107
All Time: 503
