Framework Laptop 16 DIY Edition Quick Start Guide
View statistics:
Past 24 Hours:
4
Past 7 Days:
28
Past 30 Days:
72
All Time:
387
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Easy
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Congratulations on getting the Framework Laptop 16 DIY Edition! Follow this quick start guide to assemble your laptop and get it running.
    1. Framework Laptop 16 DIY Edition Quick Start Guide, Unbox your laptop: step 1, image 1 of 2 Framework Laptop 16 DIY Edition Quick Start Guide, Unbox your laptop: step 1, image 2 of 2
      • Unbox your Framework Laptop and make sure you've received the following items:
      • Framework Laptop chassis with pre-installed Mid Plate, Touchpad Module, and Touch Spacers.
      • Bezel
      • Keyboard and Input Modules
      • Memory and Storage
      • Expansion Cards
      • Power Adapter
      • Framework Screwdriver
      Ask FixBot
    2. Framework Laptop 16 DIY Edition Quick Start Guide, Open the laptop: step 2, image 1 of 2 Framework Laptop 16 DIY Edition Quick Start Guide, Open the laptop: step 2, image 2 of 2
      • Open the laptop.
      Ask FixBot
    3. Framework Laptop 16 DIY Edition Quick Start Guide, Remove the plastic cover: step 3, image 1 of 2 Framework Laptop 16 DIY Edition Quick Start Guide, Remove the plastic cover: step 3, image 2 of 2
      • Remove the plastic cover.
      • The protective cover is made of post-consumer recycled PET and is highly recyclable. Please recycle this with your household recycling.
      Ask FixBot
    4. Framework Laptop 16 DIY Edition Quick Start Guide, Unlock the Input Modules: step 4, image 1 of 2 Framework Laptop 16 DIY Edition Quick Start Guide, Unlock the Input Modules: step 4, image 2 of 2
      • Use your fingernail to pull out the Input Module latch and unlock the Touchpad Spacer next to it.
      Ask FixBot
    5. Framework Laptop 16 DIY Edition Quick Start Guide, Remove the Touchpad Spacer: step 5, image 1 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Remove the Touchpad Spacer: step 5, image 2 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Remove the Touchpad Spacer: step 5, image 3 of 3
      • Use your fingers to slide the Touchpad Spacer toward the bottom edge of the laptop and unclip it.
      • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
      • Lift the Touchpad Spacer off the laptop and remove it.
      Ask FixBot
    6. Framework Laptop 16 DIY Edition Quick Start Guide: step 6, image 1 of 3 Framework Laptop 16 DIY Edition Quick Start Guide: step 6, image 2 of 3 Framework Laptop 16 DIY Edition Quick Start Guide: step 6, image 3 of 3
      • Repeat the previous two steps to remove the other Touchpad Spacer.
      Ask FixBot
    7. Framework Laptop 16 DIY Edition Quick Start Guide, Remove the Touchpad Module: step 7, image 1 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Remove the Touchpad Module: step 7, image 2 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Remove the Touchpad Module: step 7, image 3 of 3
      • Use your fingers to slide the Touchpad Module toward the bottom edge of the laptop and disconnect it.
      • Lift the Touchpad Module and remove it.
      Ask FixBot
    8. Framework Laptop 16 DIY Edition Quick Start Guide, Disconnect the Mid Plate cable: step 8, image 1 of 2 Framework Laptop 16 DIY Edition Quick Start Guide, Disconnect the Mid Plate cable: step 8, image 2 of 2
      • Grip the black pull tab on the Mid Plate cable press connector and lift up to disconnect it.
      Ask FixBot
    9. Framework Laptop 16 DIY Edition Quick Start Guide, Loosen the Mid Plate screws: step 9, image 1 of 2 Framework Laptop 16 DIY Edition Quick Start Guide, Loosen the Mid Plate screws: step 9, image 2 of 2
      • The Mid Plate screws are ordered from 2–17 (number 1 is the press connector). You don't have to follow the order, but you can use it to help keep track of the screws you've loosened.
      • Use your Framework Screwdriver to loosen the 16 captive T5 Torx screws securing the Mid Plate.
      Ask FixBot
    10. Framework Laptop 16 DIY Edition Quick Start Guide, Remove the Mid Plate: step 10, image 1 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Remove the Mid Plate: step 10, image 2 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Remove the Mid Plate: step 10, image 3 of 3
      • Use your fingers to lift the Mid Plate off the laptop and remove it.
      Ask FixBot
    11. Framework Laptop 16 DIY Edition Quick Start Guide, Install the memory: step 11, image 1 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Install the memory: step 11, image 2 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Install the memory: step 11, image 3 of 3
      • Hold the memory module by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
      • Orient the module with its label facing down and align the gold contacts with the left socket labeled DDR5 Channel 0.
      • Insert the contact edge into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
      • Press the edges of the memory module down until the side clips lock it in place.
      Ask FixBot
    12. Framework Laptop 16 DIY Edition Quick Start Guide: step 12, image 1 of 3 Framework Laptop 16 DIY Edition Quick Start Guide: step 12, image 2 of 3 Framework Laptop 16 DIY Edition Quick Start Guide: step 12, image 3 of 3
      • If you're using two memory modules, orient the other module so its label is facing upward and repeat the previous step for the other socket labeled DDR5 Channel 1.
      Ask FixBot
    13. Framework Laptop 16 DIY Edition Quick Start Guide, Remove the blue liner: step 13, image 1 of 2 Framework Laptop 16 DIY Edition Quick Start Guide, Remove the blue liner: step 13, image 2 of 2
      • If you're installing a secondary SSD, follow the next five steps. Otherwise, skip here.
      • Remove the blue liner from the secondary SSD thermal pad.
      • The thermal pad can vary in color—yours may be gray, orange, or pink.
      Ask FixBot
    14. Framework Laptop 16 DIY Edition Quick Start Guide, Remove the secondary SSD screw: step 14, image 1 of 2 Framework Laptop 16 DIY Edition Quick Start Guide, Remove the secondary SSD screw: step 14, image 2 of 2
      • Use your Framework Screwdriver to remove the 2 mm‑long T5 Torx screw securing the secondary SSD.
      Ask FixBot
    15. Framework Laptop 16 DIY Edition Quick Start Guide, Install the secondary SSD: step 15, image 1 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Install the secondary SSD: step 15, image 2 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Install the secondary SSD: step 15, image 3 of 3
      • Hold the SSD by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
      • Align the SSD's gold contacts with its socket.
      • Insert the SSD partially into the socket at a shallow angle. You should still be able to see most of the gold contacts.
      • Press the SSD flat to the Mainboard.
      Ask FixBot
    16. Framework Laptop 16 DIY Edition Quick Start Guide: step 16, image 1 of 2 Framework Laptop 16 DIY Edition Quick Start Guide: step 16, image 2 of 2
      • While keeping the SSD flat to the Mainboard, use your finger to slide the SSD into its socket until its golden contacts are completely covered.
      Ask FixBot
    17. Framework Laptop 16 DIY Edition Quick Start Guide, Install the secondary SSD screw: step 17, image 1 of 2 Framework Laptop 16 DIY Edition Quick Start Guide, Install the secondary SSD screw: step 17, image 2 of 2
      • Use a Framework Screwdriver to install the 2 mm‑long T5 Torx screw securing the secondary SSD.
      Ask FixBot
    18. Framework Laptop 16 DIY Edition Quick Start Guide, Remove the primary SSD screw: step 18, image 1 of 2 Framework Laptop 16 DIY Edition Quick Start Guide, Remove the primary SSD screw: step 18, image 2 of 2
      • Use your Framework Screwdriver to remove the 2 mm‑long T5 Torx screw securing the primary SSD.
      Ask FixBot
    19. Framework Laptop 16 DIY Edition Quick Start Guide, Install the primary SSD: step 19, image 1 of 2 Framework Laptop 16 DIY Edition Quick Start Guide, Install the primary SSD: step 19, image 2 of 2
      • Insert the SSD into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
      • The SSD fits into the socket in one orientation. If it doesn't feel like it fits, try flipping the module.
      Ask FixBot
    20. Framework Laptop 16 DIY Edition Quick Start Guide, Install the primary SSD screw: step 20, image 1 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Install the primary SSD screw: step 20, image 2 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Install the primary SSD screw: step 20, image 3 of 3
      • While holding the SSD flat to the Mainboard, use your Framework Screwdriver to install the 2 mm‑long T5 Torx screw securing the primary SSD.
      Ask FixBot
    21. Framework Laptop 16 DIY Edition Quick Start Guide, Remove the Mid Plate liner: step 21, image 1 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Remove the Mid Plate liner: step 21, image 2 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Remove the Mid Plate liner: step 21, image 3 of 3
      • If there's a blue liner on the thermal pad located on the bottom of the Mid Plate, use your fingers to peel it off.
      Ask FixBot
    22. Framework Laptop 16 DIY Edition Quick Start Guide, Place the Mid Plate: step 22, image 1 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Place the Mid Plate: step 22, image 2 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Place the Mid Plate: step 22, image 3 of 3
      • Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs.
      Ask FixBot
    23. Framework Laptop 16 DIY Edition Quick Start Guide, Tighten the Mid Plate screws: step 23, image 1 of 2 Framework Laptop 16 DIY Edition Quick Start Guide, Tighten the Mid Plate screws: step 23, image 2 of 2
      • Use your Framework Screwdriver to tighten the 16 T5 Torx captive screws in order (starting with 2) to secure the Mid Plate evenly.
      Ask FixBot
    24. Framework Laptop 16 DIY Edition Quick Start Guide, Connect the Mid Plate cable: step 24, image 1 of 2 Framework Laptop 16 DIY Edition Quick Start Guide, Connect the Mid Plate cable: step 24, image 2 of 2
      • Align the Mid Plate cable press connector over its socket and press down to connect it.
      Ask FixBot
    25. Framework Laptop 16 DIY Edition Quick Start Guide, Install the Input Modules: step 25, image 1 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Install the Input Modules: step 25, image 2 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Install the Input Modules: step 25, image 3 of 3
      • The top row of the laptop is fully customizable, but each Input Module follows the same installation procedure. The next three steps show installing the combination used in the first photo.
      • Check out this page for all of the possible Input Module combinations.
      Ask FixBot
    26. Framework Laptop 16 DIY Edition Quick Start Guide: step 26, image 1 of 3 Framework Laptop 16 DIY Edition Quick Start Guide: step 26, image 2 of 3 Framework Laptop 16 DIY Edition Quick Start Guide: step 26, image 3 of 3
      • Hold the Input Module at a slight downward angle and align it with one of the dotted lines on the Mid Plate.
      • Slide the top lip of the Input Module underneath the ventilation plate and lay the module down flat to let the magnets pull it into place.
      • Make sure the alignment pegs are slotted into the Input Module and that it sits flat. Otherwise, pull the module off the laptop and readjust it.
      Ask FixBot
    27. Framework Laptop 16 DIY Edition Quick Start Guide: step 27, image 1 of 3 Framework Laptop 16 DIY Edition Quick Start Guide: step 27, image 2 of 3 Framework Laptop 16 DIY Edition Quick Start Guide: step 27, image 3 of 3
      • Repeat the previous step for the other Input Module.
      • If you've already installed a numpad, you'll only have space for the keyboard and not another module.
      Ask FixBot
    28. Framework Laptop 16 DIY Edition Quick Start Guide, Install the keyboard: step 28, image 1 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Install the keyboard: step 28, image 2 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Install the keyboard: step 28, image 3 of 3
      • Hold the keyboard at a slight downward angle and align it with two of the dotted lines on the Mid Plate.
      • The keyboard can be placed on the left, center, or right edges of the laptop depending on which Input Modules you've installed.
      • Slide the top lip of the keyboard underneath the ventilation plate and lay the keyboard down flat to let the magnets pull it into place.
      • Make sure the alignment pegs are slotted into the keyboard and that it sits flat. Otherwise, pull the keyboard off the laptop and readjust it.
      Ask FixBot
    29. Framework Laptop 16 DIY Edition Quick Start Guide, Bottom row information: step 29, image 1 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Bottom row information: step 29, image 2 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Bottom row information: step 29, image 3 of 3
      • The bottom row of the laptop is fully customizable. The next four steps show installing the combination used in the first photo.
      • Note: for the Touchpad Module to be on the left, the keyboard can't be installed in the center.
      Ask FixBot
    30. Framework Laptop 16 DIY Edition Quick Start Guide, Install the Touchpad Spacers: step 30, image 1 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Install the Touchpad Spacers: step 30, image 2 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Install the Touchpad Spacers: step 30, image 3 of 3
      • Place the Touchpad Spacer over its spot on the laptop with the bottom edge overhanging slightly.
      • Slide the Touchpad Spacer towards the top of the laptop to secure it.
      Ask FixBot
    31. Framework Laptop 16 DIY Edition Quick Start Guide: step 31, image 1 of 3 Framework Laptop 16 DIY Edition Quick Start Guide: step 31, image 2 of 3 Framework Laptop 16 DIY Edition Quick Start Guide: step 31, image 3 of 3
      • Repeat the previous step for the other Touchpad Spacer.
      Ask FixBot
    32. Framework Laptop 16 DIY Edition Quick Start Guide, Install the Touchpad Module: step 32, image 1 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Install the Touchpad Module: step 32, image 2 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Install the Touchpad Module: step 32, image 3 of 3
      • Place the Touchpad Module flat on its cutout so its clips are properly aligned.
      • Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
      Ask FixBot
    33. Framework Laptop 16 DIY Edition Quick Start Guide, Lock the Input Modules: step 33, image 1 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Lock the Input Modules: step 33, image 2 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Lock the Input Modules: step 33, image 3 of 3
      • Push the Input Module latches back into place to lock them.
      Ask FixBot
    34. Framework Laptop 16 DIY Edition Quick Start Guide, Install the bezel: step 34, image 1 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Install the bezel: step 34, image 2 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Install the bezel: step 34, image 3 of 3
      • Align the bezel over the perimeter of the display and let the magnets pull the bezel into place.
      • The bezel should "snap" into place. If it doesn't, realign it and make sure it sits flush with the display.
      Ask FixBot
    35. Framework Laptop 16 DIY Edition Quick Start Guide, Reposition the laptop: step 35, image 1 of 2 Framework Laptop 16 DIY Edition Quick Start Guide, Reposition the laptop: step 35, image 2 of 2
      • Close the laptop and flip it over.
      Ask FixBot
    36. Framework Laptop 16 DIY Edition Quick Start Guide, Install the Expansion Cards: step 36, image 1 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Install the Expansion Cards: step 36, image 2 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Install the Expansion Cards: step 36, image 3 of 3
      • If you have the AMD Ryzen™ 7040 Series, click here for information on Expansion Card compatibility.
      • If you have the AMD Ryzen™ AI 300 Series, click here for information on Expansion Card compatibility.
      • Slide an Expansion Card into an Expansion Card slot.
      • You don't need to unlock the latch to install the Expansion Cards—only when you want to remove them.
      • The Expansion Cards should click into place, and the front edge should be flush with the laptop.
      • Repeat for the remaining Expansion Cards along that edge.
      Ask FixBot
    37. Framework Laptop 16 DIY Edition Quick Start Guide: step 37, image 1 of 2 Framework Laptop 16 DIY Edition Quick Start Guide: step 37, image 2 of 2
      • If there's a red bar showing under the Expansion Card latch, use your finger to flip the latch and lock the row of Expansion Cards above it.
      Ask FixBot
    38. Framework Laptop 16 DIY Edition Quick Start Guide: step 38, image 1 of 3 Framework Laptop 16 DIY Edition Quick Start Guide: step 38, image 2 of 3 Framework Laptop 16 DIY Edition Quick Start Guide: step 38, image 3 of 3
      • Repeat the previous two steps for the other row of Expansion Cards.
      Ask FixBot
    39. Framework Laptop 16 DIY Edition Quick Start Guide, Assemble the Framework Power Adapter: step 39, image 1 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Assemble the Framework Power Adapter: step 39, image 2 of 3 Framework Laptop 16 DIY Edition Quick Start Guide, Assemble the Framework Power Adapter: step 39, image 3 of 3
      • Plug the AC Cable into the Power Adapter.
      • Plug the USB-C Cable into the Power Adapter.
      • You can plug either end of the USB-C cable into the adapter.
      • Plug the AC Cable into a power outlet.
      Ask FixBot
    40. Framework Laptop 16 DIY Edition Quick Start Guide, Plug in the laptop: step 40, image 1 of 1
      • Your Framework Laptop ships in shipping mode, where the battery is disabled until you plug the laptop in for the first time.
      • Plug the USB-C Cable into any USB-C port on your laptop.
      Ask FixBot
    41. Framework Laptop 16 DIY Edition Quick Start Guide, Install an OS: step 41, image 1 of 1
      • You're done assembling your Framework Laptop! Now, you'll need to install an OS.
      • If you're installing Microsoft Windows, check out this guide.
      • If you're installing Linux, check this page for more details.
      • For drivers, firmware, and software updates, check out this page.
      Ask FixBot
If you need help, contact Framework support.
Alex Diaz-Kokaisl
251,591 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 72
All Time: 387
