Shop the Holiday Gift Guide
Framework Laptop 16 Bottom Cover Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
28
Past 30 Days:
102
All Time:
372
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Use this guide to remove and replace the Bottom Cover in your Framework Laptop 16.
    1. Framework Laptop 16 Bottom Cover Replacement, Before you begin: step 1, image 1 of 1
      • Unplug all cables and fully shut down your laptop.
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Reposition the laptop: step 2, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Reposition the laptop: step 2, image 2 of 2
      • Close the laptop and flip it over.
      Ask FixBot
    2. Framework Laptop 16 Bottom Cover Replacement, Remove the Expansion Cards: step 3, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Remove the Expansion Cards: step 3, image 2 of 2
      • Use your finger to flip the Expansion Card latches into the unlocked position.
      • The latch displays a red bar when it's unlocked.
      Ask FixBot
    3. Framework Laptop 16 Bottom Cover Replacement: step 4, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement: step 4, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement: step 4, image 3 of 3
      • Grip the lip of the Expansion Card with your fingers.
      • Pull the Expansion Card out of its slot and remove it.
      • This might take some initial force. If you're having trouble, make sure the locking tab is properly unlocked.
      • Repeat for all remaining Expansion Cards.
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Unlock the Input Modules: step 5, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Unlock the Input Modules: step 5, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Unlock the Input Modules: step 5, image 3 of 3
      • Use your fingernail to pull out the two Input Module latches and unlock them.
      • The latch will show red if it's unlocked.
      Ask FixBot
    2. Framework Laptop 16 Bottom Cover Replacement, Remove the Touchpad Spacers: step 6, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the Touchpad Spacers: step 6, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the Touchpad Spacers: step 6, image 3 of 3
      • Use your fingers to slide the Touchpad Spacer toward the bottom edge of the laptop and unclip it.
      • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
      • Lift the Touchpad Spacer off the laptop and remove it.
      Ask FixBot
    3. Framework Laptop 16 Bottom Cover Replacement: step 7, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement: step 7, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement: step 7, image 3 of 3
      • Repeat the same procedure for the other touchpad spacer.
      Ask FixBot
    4. Framework Laptop 16 Bottom Cover Replacement, Remove the Touchpad Module: step 8, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the Touchpad Module: step 8, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the Touchpad Module: step 8, image 3 of 3
      • Use your fingers to slide the Touchpad Module toward the bottom edge of the laptop and disconnect it.
      • If you're having trouble, check if the Input Module latches are properly unlocked.
      • Lift the Touchpad Module and remove it.
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Remove the keyboard: step 9, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the keyboard: step 9, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the keyboard: step 9, image 3 of 3
      • The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
      • Grip the two pull tabs along the bottom of the keyboard and lift until its magnets release.
      • Remove the keyboard.
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Remove the Input Modules: step 10, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the Input Modules: step 10, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the Input Modules: step 10, image 3 of 3
      • Your Input Module(s) might be different, but the procedure to remove them is the same.
      • Grip the pull tab at the bottom of the Input Module and lift until its magnets release.
      • Remove the Input Module.
      • Repeat for any remaining Input Modules.
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Disconnect the Mid Plate cable: step 11, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Disconnect the Mid Plate cable: step 11, image 2 of 2
      • Grip the black pull tab on the Mid Plate cable press connector.
      • Lift up to disconnect the Mid Plate cable.
      Ask FixBot
    2. Framework Laptop 16 Bottom Cover Replacement, Loosen the Mid Plate screws: step 12, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Loosen the Mid Plate screws: step 12, image 2 of 2
      • The Mid Plate screws are ordered from 2–17 (number 1 is the press connector). You don't have to follow the order, but you can use it to help keep track of the screws you've loosened.
      • Use your Framework Screwdriver to loosen the 16 captive T5 Torx screws securing the Mid Plate.
      Ask FixBot
    3. Framework Laptop 16 Bottom Cover Replacement, Remove the Mid Plate: step 13, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the Mid Plate: step 13, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the Mid Plate: step 13, image 3 of 3
      • Use your fingers to lift the Mid Plate off the laptop and remove it.
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Loosen the battery screws: step 14, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Loosen the battery screws: step 14, image 2 of 2
      • Use your Framework Screwdriver to loosen the three captive T5 Torx screws securing the battery.
      Ask FixBot
    2. Framework Laptop 16 Bottom Cover Replacement, Remove the battery: step 15, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the battery: step 15, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the battery: step 15, image 3 of 3
      • Grip the black pull tab at the top of the battery and lift to disconnect the battery connector.
      • Remove the battery.
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Disconnect the speaker: step 16, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Disconnect the speaker: step 16, image 2 of 2
      • Lift the speaker cable connector by its black pull tab and disconnect it.
      Ask FixBot
    2. Framework Laptop 16 Bottom Cover Replacement, Reroute the speaker cable: step 17, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Reroute the speaker cable: step 17, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Reroute the speaker cable: step 17, image 3 of 3
      • The speaker cable is routed along the bottom edge of the laptop. The next three steps will demonstrate how to unclip it.
      • Starting at one speaker, use the flat end of a spudger, or your fingers, to lift the speaker cable out of its rubber clips.
      Ask FixBot
    3. Framework Laptop 16 Bottom Cover Replacement: step 18, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement: step 18, image 2 of 2
      • Slide the speaker cable out from under its screw hole peg in the frame.
      Ask FixBot
    4. Framework Laptop 16 Bottom Cover Replacement: step 19, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement: step 19, image 2 of 2
      • Repeat the last two steps across the length of the speaker cable until it's completely unclipped.
      Ask FixBot
    5. Framework Laptop 16 Bottom Cover Replacement, Remove the speaker screws: step 20, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Remove the speaker screws: step 20, image 2 of 2
      • Use your Framework Screwdriver to remove the two 2.0 mm‑long T5 Torx screws securing each speaker (four in total).
      Ask FixBot
    6. Framework Laptop 16 Bottom Cover Replacement, Remove the speakers: step 21, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the speakers: step 21, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the speakers: step 21, image 3 of 3
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Lift the interposer door: step 22, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Lift the interposer door: step 22, image 2 of 2
      • Lift the interposer door by its black pull tab and let it rest upright.
      Ask FixBot
    2. Framework Laptop 16 Bottom Cover Replacement, Loosen the interposer screws: step 23, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Loosen the interposer screws: step 23, image 2 of 2
      • If you have the Graphics Module installed, your interposer will have four screws. If you have the Expansion Bay Shell installed, you'll have three screws instead.
      • If you have the Graphics Module, use your Framework Screwdriver to loosen the four captive T5 Torx screws securing the interposer.
      • If you have the Expansion Bay Shell, use your Framework Screwdriver to loosen the three captive T5 Torx screws securing the interposer.
      Ask FixBot
    3. Framework Laptop 16 Bottom Cover Replacement, Remove the interposer: step 24, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Remove the interposer: step 24, image 2 of 2
      • Lift the interposer by its pull tab and remove it.
      Ask FixBot
    4. Framework Laptop 16 Bottom Cover Replacement, Loosen the Expansion Bay Module screws: step 25, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Loosen the Expansion Bay Module screws: step 25, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Loosen the Expansion Bay Module screws: step 25, image 3 of 3
      • Use your Framework Screwdriver to loosen the two captive T5 Torx screws securing the module in the Expansion Bay.
      • Close the interposer door before continuing.
      Ask FixBot
    5. Framework Laptop 16 Bottom Cover Replacement, Remove the Expansion Bay Module: step 26, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the Expansion Bay Module: step 26, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the Expansion Bay Module: step 26, image 3 of 3
      • Close your laptop and flip it over.
      • Slide the Expansion Bay Module out of the laptop and remove it.
      • The module should slide out easily. If you feel any resistance, check if the screws holding it in place are fully loosened.
      • Flip your laptop and reopen it.
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Disconnect the fingerprint reader: step 27, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Disconnect the fingerprint reader: step 27, image 2 of 2
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to lift up the locking tab on the fingerprint reader ZIF connector next to the memory.
      Ask FixBot
    2. Framework Laptop 16 Bottom Cover Replacement: step 28, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement: step 28, image 2 of 2
      • Use your fingers to grip the blue pull tab and slide the fingerprint reader cable straight out of its socket.
      Ask FixBot
    3. Framework Laptop 16 Bottom Cover Replacement: step 29, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement: step 29, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement: step 29, image 3 of 3
      • The fingerprint reader cable is lightly adhered to the laptop's frame.
      • Use your fingers to peel the fingerprint reader cable away from the frame and separate the adhesive.
      Ask FixBot
    4. Framework Laptop 16 Bottom Cover Replacement, Remove the ventilation plate: step 30, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the ventilation plate: step 30, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the ventilation plate: step 30, image 3 of 3
      • The ventilation plate is held in place with magnets.
      • Lift the bottom of the ventilation plate and pull it away from the laptop until the magnets release.
      • Remove the ventilation plate.
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Loosen the Wi-Fi module screw: step 31, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Loosen the Wi-Fi module screw: step 31, image 2 of 2
      • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing Wi-Fi module.
      • The module might pop up at a shallow angle when you loosen the screw.
      Ask FixBot
    2. Framework Laptop 16 Bottom Cover Replacement, Remove the Wi-Fi module cover: step 32, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Remove the Wi-Fi module cover: step 32, image 2 of 2
      • Slide the clear plastic cover straight off the module and remove it.
      Ask FixBot
    3. Framework Laptop 16 Bottom Cover Replacement, Disconnect the Wi-Fi module: step 33, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Disconnect the Wi-Fi module: step 33, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Disconnect the Wi-Fi module: step 33, image 3 of 3
      • While holding the Wi-Fi module down, insert the flat end of your Framework Screwdriver one of the coaxial connectors, where the cable meets the metal head.
      • Lift the screwdriver straight up to disconnect the coaxial cable.
      • Repeat for the other coaxial cable.
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Create a gap: step 34, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Create a gap: step 34, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Create a gap: step 34, image 3 of 3
      • The bezel is secured with magnets.
      • Slide your fingernail under the inside edge of either bottom corner of the bezel.
      • Pull the bezel away from the screen to release the first few magnets.
      Ask FixBot
    2. Framework Laptop 16 Bottom Cover Replacement, Remove the bezel: step 35, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the bezel: step 35, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the bezel: step 35, image 3 of 3
      • Lift the bezel around the perimeter of the screen until all of its magnets are released.
      • Remove the bezel.
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Disconnect the display cables: step 36, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Disconnect the display cables: step 36, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Disconnect the display cables: step 36, image 3 of 3
      • Grip the eDP cable connector to the right of the Wi-Fi module slot by its pull tab and lift up to disconnect it.
      • Repeat for the webcam cable connector next to it.
      Ask FixBot
    2. Framework Laptop 16 Bottom Cover Replacement, Reroute the cables: step 37, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Reroute the cables: step 37, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Reroute the cables: step 37, image 3 of 3
      • Lift the eDP, webcam, and antenna cables out of their vertical slot in the Bottom Cover.
      Ask FixBot
    3. Framework Laptop 16 Bottom Cover Replacement: step 38, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement: step 38, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement: step 38, image 3 of 3
      • Use your fingers to guide the eDP cable out of its clips along the top left edge of the Bottom Cover.
      Ask FixBot
    4. Framework Laptop 16 Bottom Cover Replacement: step 39, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement: step 39, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement: step 39, image 3 of 3
      • Repeat the previous step for the black antenna cable.
      Ask FixBot
    5. Framework Laptop 16 Bottom Cover Replacement: step 40, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement: step 40, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement: step 40, image 3 of 3
      • Use your fingers to guide the white antenna cable out of its clips along the top right edge of the Bottom Cover.
      Ask FixBot
    6. Framework Laptop 16 Bottom Cover Replacement: step 41, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement: step 41, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement: step 41, image 3 of 3
      • Repeat the previous step for the webcam cable.
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Remove the hinge screws: step 42, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the hinge screws: step 42, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the hinge screws: step 42, image 3 of 3
      • While supporting the Top Cover with one hand, use your Framework Screwdriver to remove the four 3.9 mm‑long screws on each hinge connected to the Bottom Cover (8 total).
      Ask FixBot
    2. Framework Laptop 16 Bottom Cover Replacement: step 43, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement: step 43, image 2 of 2
      • Lift the Top Cover from the Bottom Cover and remove it.
      Ask FixBot
    3. Framework Laptop 16 Bottom Cover Replacement, Remove the Mainboard screws: step 44, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Remove the Mainboard screws: step 44, image 2 of 2
      • Lift up the interposer door to reveal the screw underneath.
      • The Mainboard screws are ordered from 1–6. You don't have to follow the order, but you can use it to help keep track of the screws you've removed.
      • Use your Framework Screwdriver to remove the six 2.0 mm‑long T5 Torx screws securing the Mainboard.
      Ask FixBot
    4. Framework Laptop 16 Bottom Cover Replacement, Remove the Mainboard: step 45, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the Mainboard: step 45, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the Mainboard: step 45, image 3 of 3
      • Use your fingers to lift the bottom edge of the Mainboard enough to grip its edges.
      • Lift the Mainboard off its alignment pegs and remove it.
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Disassembly complete: step 46, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Bottom Cover information: step 47, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Bottom Cover information: step 47, image 2 of 2
      • The replacement Bottom Cover comes with pre-installed screws for the hinge, Mainboard, and the speakers. During reassembly, use those screws to replace your old ones.
      Ask FixBot
    2. Framework Laptop 16 Bottom Cover Replacement, Remove the liner: step 48, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the liner: step 48, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Remove the liner: step 48, image 3 of 3
      • If you have a secondary SSD installed, remove the blue liner on the thermal pad.
      Ask FixBot
    3. Framework Laptop 16 Bottom Cover Replacement, Place the Mainboard: step 49, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Place the Mainboard: step 49, image 2 of 2
      • Place the Mainboard into the laptop and onto its alignment pegs.
      Ask FixBot
    4. Framework Laptop 16 Bottom Cover Replacement, Install the Mainboard screws: step 50, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Install the Mainboard screws: step 50, image 2 of 2
      • Use your Framework Screwdriver to install the six 2.0 mm‑long T5 Torx screws securing the Mainboard.
      Ask FixBot
    5. Framework Laptop 16 Bottom Cover Replacement, Place the Top Cover: step 51, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Place the Top Cover: step 51, image 2 of 2
      • Place the Top Cover over Bottom Top Cover, making sure the hinges are slotted into their alignment pegs.
      Ask FixBot
    6. Framework Laptop 16 Bottom Cover Replacement, Install the hinge screws: step 52, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Install the hinge screws: step 52, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Install the hinge screws: step 52, image 3 of 3
      • While supporting the Top Cover with one hand, use your Framework Screwdriver to install the four 3.9 mm‑long screws on each hinge connected to the Bottom Cover (8 total).
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Reroute the cables: step 53, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Reroute the cables: step 53, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Reroute the cables: step 53, image 3 of 3
      • Use the flat end of your Framework Screwdriver, or your fingers, to press the webcam cable into its clips at the top right edge of the Bottom Cover.
      Ask FixBot
    2. Framework Laptop 16 Bottom Cover Replacement: step 54, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement: step 54, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement: step 54, image 3 of 3
      • Repeat the previous step for the white antenna cable.
      Ask FixBot
    3. Framework Laptop 16 Bottom Cover Replacement: step 55, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement: step 55, image 2 of 2
      • Use the flat end of your Framework Screwdriver, or your fingers, to press the black antenna cable into its clips at the top left edge of the Bottom Cover.
      Ask FixBot
    4. Framework Laptop 16 Bottom Cover Replacement: step 56, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement: step 56, image 2 of 2
      • Repeat the previous step for the eDP cable.
      Ask FixBot
    5. Framework Laptop 16 Bottom Cover Replacement: step 57, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement: step 57, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement: step 57, image 3 of 3
      • Press the eDP, webcam, and antenna cables into their vertical slot in the Bottom Cover.
      Ask FixBot
    6. Framework Laptop 16 Bottom Cover Replacement, Connect the display cables: step 58, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Connect the display cables: step 58, image 2 of 2
      • Press the eDP and webcam cable connectors straight down into their sockets to connect them.
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Install the bezel: step 59, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Install the bezel: step 59, image 2 of 2
      • Align the bezel over the perimeter of the display and let the magnets pull the bezel into place.
      • The bezel should "snap" into place. If it doesn't, realign it and make sure it sits flush with the display.
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Connect the Wi-Fi module: step 60, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Connect the Wi-Fi module: step 60, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Connect the Wi-Fi module: step 60, image 3 of 3
      • Hold the Wi-Fi module down with your finger.
      • Position the white antenna cable connector over the left Wi-Fi module's coaxial socket.
      • If you're unsure which cable goes where, refer to the arrows on the Wi-Fi module for which color cable matches with its connector.
      • Tweezers can help position the connector.
      • Use your finger to press the connector into place. You should feel a faint click, and the cable will stay attached to the socket by itself.
      • These connectors are very delicate! If the connector doesn't feel like it's clicking in place, reposition the connector and try again.
      • Repeat the procedure with the black antenna cable.
      Ask FixBot
    2. Framework Laptop 16 Bottom Cover Replacement, Remove the Wi-Fi module cover: step 61, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Remove the Wi-Fi module cover: step 61, image 2 of 2
      • Slide the clear plastic cover on the module and align its screw with the screw hole cutout.
      Ask FixBot
    3. Framework Laptop 16 Bottom Cover Replacement, Tighten the Wi-Fi module screw: step 62, image 1 of 1
      • Use your Framework Screwdriver to tighten the captive T5 Torx screw securing Wi-Fi module.
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Place the ventilation plate: step 63, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Place the ventilation plate: step 63, image 2 of 2
      • Lay the ventilation plate along the top edge of the laptop and let its magnets pull into place.
      Ask FixBot
    2. Framework Laptop 16 Bottom Cover Replacement, Connect the fingerprint reader: step 64, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Connect the fingerprint reader: step 64, image 2 of 2
      • Use your fingers to grip the blue pull tab and slide the fingerprint reader cable straight into its socket.
      Ask FixBot
    3. Framework Laptop 16 Bottom Cover Replacement: step 65, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement: step 65, image 2 of 2
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to press down the locking tab on the fingerprint reader ZIF connector.
      Ask FixBot
    4. Framework Laptop 16 Bottom Cover Replacement: step 66, image 1 of 1
      • Press the fingerprint reader cable to the frame to re-adhere it.
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Lift the interposer door: step 67, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Lift the interposer door: step 67, image 2 of 2
      • Close the interposer door.
      Ask FixBot
    2. Framework Laptop 16 Bottom Cover Replacement, Tighten the interposer screws: step 68, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Tighten the interposer screws: step 68, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Tighten the interposer screws: step 68, image 3 of 3
      • If you have the Graphics Module, use your Framework Screwdriver to tighten the four captive T5 Torx screws securing the interposer.
      • If you have the Expansion Bay Shell, use your Framework Screwdriver to tighten the three captive T5 Torx screws securing the interposer.
      Ask FixBot
    3. Framework Laptop 16 Bottom Cover Replacement, Place the interposer: step 69, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Place the interposer: step 69, image 2 of 2
      • Place the interposer over its spot between the Mainboard and the module.
      • Depending on if you're installing a Graphics Module or the Expansion Bay Shell, the interposer should be oriented so either rubber grommets or metal tabs cover the Expansion Bay screws.
      Ask FixBot
    4. Framework Laptop 16 Bottom Cover Replacement, Tighten the Expansion Bay Module screws: step 70, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Tighten the Expansion Bay Module screws: step 70, image 2 of 2
      • Use your Framework Screwdriver to tighten the two captive T5 Torx screws securing the Expansion Bay Module.
      Ask FixBot
    5. Framework Laptop 16 Bottom Cover Replacement, Insert the Expansion Bay Module: step 71, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Insert the Expansion Bay Module: step 71, image 2 of 2
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Place the speakers: step 72, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Place the speakers: step 72, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Place the speakers: step 72, image 3 of 3
      • Align the speakers over their alignment pegs and press them down into place.
      Ask FixBot
    2. Framework Laptop 16 Bottom Cover Replacement, Install the speaker screws: step 73, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Install the speaker screws: step 73, image 2 of 2
      • Be very careful replacing these screws, as it's easy to damage their posts and prevent the screws from fully tightening. Don't overtighten the screws—just tighten them until they're snug.
      • Use your Framework Screwdriver to install the two 2.0 mm‑long T5 Torx screws securing each speaker (four in total).
      Ask FixBot
    3. Framework Laptop 16 Bottom Cover Replacement, Reroute the speaker cable: step 74, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Reroute the speaker cable: step 74, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Reroute the speaker cable: step 74, image 3 of 3
      • Use the flat end of your Framework Screwdriver to push the speaker cable back into its clips along the bottom edge of the laptop.
      Ask FixBot
    4. Framework Laptop 16 Bottom Cover Replacement, Connect the speaker: step 75, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Connect the speaker: step 75, image 2 of 2
      • Press the speaker cable connector onto its socket to connect it.
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Install the battery: step 76, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Install the battery: step 76, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Install the battery: step 76, image 3 of 3
      • Align the battery connector over its socket and lay the battery into its well.
      • Lightly press the battery down to connect it.
      Ask FixBot
    2. Framework Laptop 16 Bottom Cover Replacement, Tighten the battery screws: step 77, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Tighten the battery screws: step 77, image 2 of 2
      • Use your Framework Screwdriver to tighten the three captive T5 Torx screws securing the battery.
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Place the Mid Plate: step 78, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Place the Mid Plate: step 78, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Place the Mid Plate: step 78, image 3 of 3
      • Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs.
      Ask FixBot
    2. Framework Laptop 16 Bottom Cover Replacement, Tighten the Mid Plate screws: step 79, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Tighten the Mid Plate screws: step 79, image 2 of 2
      • Use your Framework Screwdriver to tighten the 16 captive T5 Torx screws in order (starting with 2) to secure the Mid Plate evenly.
      Ask FixBot
    3. Framework Laptop 16 Bottom Cover Replacement, Connect the Mid Plate cable: step 80, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Connect the Mid Plate cable: step 80, image 2 of 2
      • Align the Mid Plate cable press connector over its socket and press down to connect it.
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Install the Input Modules: step 81, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Install the Input Modules: step 81, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Install the Input Modules: step 81, image 3 of 3
      • Align the top edge of the Input Module with the top edge of the laptop.
      • Lay the Input Module on the laptop and let the magnets pull the keyboard into place
      • Make sure the Input Module is seated properly on its alignment pegs and sits flush with the edges of the laptop.
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Install the keyboard: step 82, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Install the keyboard: step 82, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Install the keyboard: step 82, image 3 of 3
      • Align the top edge of the keyboard with the top edge of the laptop.
      • Lay the keyboard on the laptop and let the magnets pull the keyboard into place
      • Make sure the keyboard is seated properly on its alignment pegs and sits flush with the edges of the laptop.
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Install the Touchpad Module: step 83, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Install the Touchpad Module: step 83, image 2 of 2
      • Place the Touchpad Module flat on its cutout so its clips are properly aligned.
      • Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
      Ask FixBot
    2. Framework Laptop 16 Bottom Cover Replacement, Install the Touchpad Spacers: step 84, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Install the Touchpad Spacers: step 84, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Install the Touchpad Spacers: step 84, image 3 of 3
      • Place the Touchpad Spacer over its spot on the laptop with the bottom edge overhanging slightly.
      • Slide the Touchpad Spacer towards the top of the laptop to secure it.
      • Repeat the same procedure for the other Touchpad Spacer.
      Ask FixBot
    1. Framework Laptop 16 Bottom Cover Replacement, Reposition the laptop: step 85, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement, Reposition the laptop: step 85, image 2 of 2
      Ask FixBot
    2. Framework Laptop 16 Bottom Cover Replacement, Install the Expansion Cards: step 86, image 1 of 3 Framework Laptop 16 Bottom Cover Replacement, Install the Expansion Cards: step 86, image 2 of 3 Framework Laptop 16 Bottom Cover Replacement, Install the Expansion Cards: step 86, image 3 of 3
      • Slide an Expansion Card into an Expansion Card slot.
      • You don't need to unlock the latch to install the Expansion Cards—only when you want to remove them.
      • The Expansion Cards should click into place, and the front edge should be flush with the laptop.
      Ask FixBot
    3. Framework Laptop 16 Bottom Cover Replacement: step 87, image 1 of 2 Framework Laptop 16 Bottom Cover Replacement: step 87, image 2 of 2
      • Use your finger to flip both latches and lock the row of Expansion Cards above them.
      Ask FixBot
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
Alex Diaz-Kokaisl
252,477 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 102
All Time: 372
