Framework Laptop 13 Pro LPCAMM2 Memory Replacement
    1. Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Before you begin: step 1, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Before you begin: step 1, image 2 of 2
      • Unplug all cables and fully shut down your laptop from the OS.
      Ask FixBot
    1. Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Loosen the Input Cover screws: step 2, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Loosen the Input Cover screws: step 2, image 2 of 2
      • Use your Framework Screwdriver to loosen the five captive T5 Torx screws securing the Input Cover.
      Ask FixBot
    2. Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Lift the Input Cover: step 3, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Lift the Input Cover: step 3, image 2 of 2
      • Flip over your laptop and open it.
      • Use your fingers to lift the Input Cover up and release it from its magnets.
      • Don't fully remove the Input Cover yet, as it's still attached by the Touchpad Cable.
      • If you're having trouble lifting the Input Cover, you can leverage the gap at the bottom right corner to get your fingers fully under it.
      Ask FixBot
    3. Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Flip over the Input Cover: step 4, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Flip over the Input Cover: step 4, image 2 of 2
      • Flip the top of the Input Cover so the Keyboard is facing down.
      • Rest the Input Cover over the Battery, making sure the Touchpad Cable isn't being strained.
      • If the LEDs on the left and right sides of the Mainboard are flashing, then your laptop is still powered on. Make sure your laptop is completely powered off before continuing.
      Ask FixBot
    4. Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Disconnect the Touchpad Cable: step 5, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Disconnect the Touchpad Cable: step 5, image 2 of 2
      • Insert your finger into the Touchpad Cable press connector loop.
      • Lift up to disconnect the Touchpad Cable from the Mainboard.
      Ask FixBot
    5. Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Remove the Input Cover: step 6, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Remove the Input Cover: step 6, image 2 of 2
      • Remove the Input Cover.
      Ask FixBot
    1. Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Loosen the LPCAMM2 Memory Cover: step 7, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Loosen the LPCAMM2 Memory Cover: step 7, image 2 of 2
      • Use your Framework Screwdriver to loosen the captive T5 Torx screws securing the LPCAMM2 Memory Cover in reverse order from 3–1.
      Ask FixBot
    2. Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Remove the LPCAMM2 Memory Cover: step 8, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Remove the LPCAMM2 Memory Cover: step 8, image 2 of 2
      • Lift the LPCAMM2 Memory Cover straight off the memory and remove it.
      Ask FixBot
    1. Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Remove the LPCAMM2 Memory: step 9, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Remove the LPCAMM2 Memory: step 9, image 2 of 2
      • Grip the LPCAMM2 module by its edges and lift it straight off its alignment pegs to remove it.
      • Avoid touching the Interposer below the module. If the Interposer accidentally shifts, grab it by its edges to place it back into its alignment pegs.
      • Make sure there's no dust or debris on top of the Interposer before continuing.
      Ask FixBot
    1. Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Disassembly complete: step 10, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
      Ask FixBot
    1. Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Place the LPCAMM2 Memory: step 11, image 1 of 3 Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Place the LPCAMM2 Memory: step 11, image 2 of 3 Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Place the LPCAMM2 Memory: step 11, image 3 of 3
      • Place the LPCAMM2 module on top of the Interposer, making sure it slots into its alignment pegs.
      Ask FixBot
    1. Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Place the LPCAMM2 Memory Cover: step 12, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Place the LPCAMM2 Memory Cover: step 12, image 2 of 2
      • Place the LPCAMM2 Memory Cover on top of the memory, making sure its screws align with the screw holes.
      • The cover should lay flat when aligned properly.
      Ask FixBot
    2. Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Tighten the LPCAMM2 Memory Cover: step 13, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Tighten the LPCAMM2 Memory Cover: step 13, image 2 of 2
      • Use your Framework Screwdriver to tighten the captive T5 Torx screws securing the LPCAMM2 Memory Cover in order from 1–3.
      • Make sure the screws are snug enough to create proper contact between the memory and the Mainboard.
      Ask FixBot
    1. Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Position the Input Cover: step 14, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Position the Input Cover: step 14, image 2 of 2
      • Position the Input Cover, Keyboard down, on top of the laptop so it just covers the Battery.
      • This allows the Touchpad Cable to be folded over and reconnected without straining it.
      Ask FixBot
    2. Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Connect the Touchpad Cable: step 15, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Connect the Touchpad Cable: step 15, image 2 of 2
      • Align the press connector over its socket and press down with your finger.
      • You should hear it "click" into place. If you're having trouble, reposition it and try again. Don't try to force the connector into place.
      Ask FixBot
    3. Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Place the Input Cover: step 16, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Place the Input Cover: step 16, image 2 of 2
      • Flip the Input Cover over the laptop and align the bottom edges.
      Ask FixBot
    4. Framework Laptop 13 Pro LPCAMM2 Memory Replacement: step 17, image 1 of 3 Framework Laptop 13 Pro LPCAMM2 Memory Replacement: step 17, image 2 of 3 Framework Laptop 13 Pro LPCAMM2 Memory Replacement: step 17, image 3 of 3
      • Lay the Input Cover over the laptop and let the magnets snap it into place.
      • The bottom right corner of the Input Cover won't sit flush with the laptop until you tighten its screws.
      Ask FixBot
    5. Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Reposition the laptop: step 18, image 1 of 1
      • Close the laptop and flip it over.
      Ask FixBot
    6. Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Tighten the Input Cover screws: step 19, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Replacement, Tighten the Input Cover screws: step 19, image 2 of 2
      • Use your Framework Screwdriver to tighten the five captive T5 Torx screws securing the Input Cover.
      • Don't overtighten the screws—just make sure they're snug.
      Ask FixBot
You finished fixing your Framework Laptop! The first boot will take longer and start with a “Memory Training in Progress” screen. If you run into any errors during Memory Training, please see this page.
If you need help, contact Framework support.
Alex Diaz-Kokaisl
250,369 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 126
All Time: 381
